Need help on assembly of 71 B-body steering Column
#971154
04/11/11 12:42 PM
04/11/11 12:42 PM
Posts: 658 Dillsburg, PA
Wizard
Dillsburg, PA
I rebuilt my 71 road runner steering colomb about 6 years ago. I can't remember everything thing how everthing went inside but now I am trying to hook it up in the car and I am about 1- 1 1/2 inches short of the steering shaft from reaching the steering box gear. The adjusters up under the steering (3 ea) column are maxed out also. You can see the marks from where they used to be before I took it off and rebuilt it. What would now make the steering column shaft to short to reach the steering chuck gear? I can get the steering shaft to go over the first gear spline on the chuck but thats maxed out and the adjusters won't be able to hold up the steering column under the dash. I did have the steering chuck rebuilt by steer and gear about 6-7 years ago. Everything looks good there though and it is mounted correctly in the K member.
Wizard
Guns, God, and Country.
U.S. Veteran
Re: Need help on assembly of 71 B-body steering Column
[Re: GETX]
#971156
04/11/11 03:00 PM
04/11/11 03:00 PM
Wizard
Dillsburg, PA
If this has happened, "shear pins broken" would I be able to pull the steering rod back out without taking the column apart? The steering rod does not move up or down any from the steering wheel. I know I would have to replace the shear pins anyhow if they did break but just wondering what the characteristics would be on the steering wheel if it did happen.
Wizard
U.S. Veteran
[Re: JulesdaWiperman]
#971160
04/11/11 10:55 PM
04/11/11 10:55 PM
Wizard
Dillsburg, PA
Do I have to dissasemble the upper steering column or can I just pull on the end of the steering shaft to get the 1.5 inches I need?
Wizard
U.S. Veteran
#971162
04/12/11 12:39 AM
04/12/11 12:39 AM
Wizard
Dillsburg, PA
Appreciate it. I will give it a try.
Thanks,
wizard
U.S. Veteran
#971163
04/12/11 05:17 PM
04/12/11 05:17 PM
Posts: 4,165 Florida
cataclysm80
Just make sure you have the safety pin in the coupler installed.
I'm pretty sure my 70 Challenger has that safety pin in the coupler, but I think some of the earlier cars didn't come with it. Anyone know what year the safety pin came out?
Tav
[Re: cataclysm80]
#971164
05/26/11 10:28 PM
05/26/11 10:28 PM
Wizard
Dillsburg, PA
Well, my dad and I have been trying to pull the bottom shaft out but with no luck. We have been just trying to use our hands to pull it apart but won"t budge. Even tried putting column on ground standing on steering wheel and pulling up on it but it won't move. I was wondering how do I get it apart again up near the steering column where the wires and turn signal/key goes in? Been few years how I took it apart and can't remember, but sounds like I don't really need to take that apart again to fix this problem but would still like to know? Anyone?
Wizard
U.S. Veteran
[Re: Rockland71GTX]
#971166
05/26/11 11:47 PM
05/26/11 11:47 PM
Wizard
Dillsburg, PA
I can't seem to figure out how to remove the metal round housing that the steering shaft goes thru to be able to put oil in between the 2 pieces and also to be able to give it a rap with a mallad where the 2 pieces are inside each other.
Wizard
U.S. Veteran
