Problem with oil breather grommet hole size #971061
04/11/11 06:51 AM
04/11/11 06:51 AM
Melbourne.....Oz-land
Moparmal Offline OP
Moparmal  Offline OP
I ahve just finished paining up my M/T valve covers - only to discover thath the std oil breather rubber grommet is way too small for the existing hole.
The grommet outside diameter is 1.22 inches - but the valve cover hole is 1.5" needing something bigger than 1.5 to seat on the flange.
Can anyone point me in the right direction of where to get the correct size breather grommet?
Re: Problem with oil breather grommet hole size [Re: Moparmal] #971062
04/11/11 11:26 AM
04/11/11 11:26 AM
Philadelphia
radar Offline
radar  Offline
Philadelphia
I ended up using a rubber grommet and a breather insert for an early '70s ford. I think it might have been something like a 71 tbird 429 or something. It looks kind of like a car cigar lighter- round metal case that pushes into the bigger hole.
I asked around on here and looked all over and bought the wrong stuff a few times first. Search my name for the thread.
Rdr
Re: Problem with oil breather grommet hole size [Re: radar] #971063
04/11/11 12:15 PM
04/11/11 12:15 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Local parts store in the Dorman Help section.
Re: Problem with oil breather grommet hole size [Re: stumpy] #971064
04/11/11 12:43 PM
04/11/11 12:43 PM
Cincinnati, Ohio
chargincharles Offline
Cincinnati, Ohio
All those valve covers tend to have aftermarket or 'universal' size holes. Check the aftermarket section of your local parts store (Autozone, Advanced, O'Reilly's, whatever) and you should see them selling the grommets. Cheap too.
Good Luck,
CC.
Re: Problem with oil breather grommet hole size [Re: chargincharles] #971065
04/11/11 07:23 PM
04/11/11 07:23 PM
Moparmal Offline OP
Moparmal  Offline OP
Unfortunately what you guys have as "factory", we never got "down under"
I'll check Rock Auto and see what they list.
Cheers
MM
67 RO23 clone with 6.1 SRT Hemi and dual quads. Soon to have Drag Pak induction and Throttle body.
Re: Problem with oil breather grommet hole size [Re: Moparmal] #971066
04/12/11 07:48 AM
04/12/11 07:48 AM
Moparmal Offline OP
Moparmal  Offline OP
Success - Got some blanking grommets from a local supplier and punched the required holes through them.
