Engine sat for a year - re-prime oil or just start it?
#971010
04/11/11 01:01 AM
04/11/11 01:01 AM
Posts: 923 Missouri
convertriple
super gas
super gas
Missouri
I haven't started my car in a year, had a heater core leak that turned into an interior restore job. Should I pull the distributor and reprime with a drill or just start it up? Alternatively, I could crank it for a while with the coil wire off, but not sure if that would better or not. Anyone got experience with this?
Re: Engine sat for a year - re-prime oil or just start it?
[Re: DaytonaTurbo]
#971017
04/11/11 11:11 AM
04/11/11 11:11 AM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Hit the key and start it, it'll be fine. I've left mine sitting that long or more without issue.
Put the key in, make sure to have a fully charged battery and gas in the carb., spin it over and start it. Not an issue. I do at least 2 of them year. One I fired last had sat 3 years and had instant pressure when fired. If you had good clean oil when parked it will not be an issue at all.
[Re: MoparforLife]
#971018
04/12/11 02:15 AM
04/12/11 02:15 AM
Posts: 9,116 Tucson, AZ
Ramrod39
My New Title
My New Title
Tucson, AZ
The only thing I might prime is the carb....
[Re: Ramrod39]
#971019
04/12/11 06:32 AM
04/12/11 06:32 AM
Posts: 8,938 Holly/MI
Dean_Kuzluzski
Holly/MI
My biggest concern would be the rings/bores, I pull the plugs, spray WD-40 in each cylinder, and crank away. Since the fuel has evaporated out of the carb it's going to crank a long time until the fuel system is primed and working. Been doing this for many years on an old hobby car and it still runs hard.
[Re: Dean_Kuzluzski]
#971020
04/12/11 01:51 PM
04/12/11 01:51 PM
Posts: 1,074 detroit, mi
POS Dakota
detroit, mi
None of the bearings are a concern after a year? Just asking...
#971021
04/12/11 03:29 PM
04/12/11 03:29 PM
Posts: 159 Woodward, PA
75DART440
Woodward, PA
Started a 318 that had been sitting 20+ years. Pulled the plugs, gave each hole several squirts of motor oil from a pump-oiler type oil can, and cranked it several revoloutions. Put plugs back in, primed carb, and fired it right up. Had one lifter that ticked for 10 to 20 seconds, then it sounded fine. This was in an A100 van that had not been licensed or inspected for 23 years!!! Of course, I was using a jug with the fuel hose running into it, not the tar that was in the tank. And I did swap distributors rather than mess with the corroded old points.
Buy a Hybrid!! I need your gas!!! Currently spending $1,000 a month to feed the Hemis!!
Looking for that elusive CHEAP 71-72 Plymouth B-body 2 door OR 71-72 Coronet 4 door!!!
[Re: convertriple]
#971026
04/13/11 01:59 AM
04/13/11 01:59 AM
Ramrod39
My New Title
My New Title
Tucson, AZ
Thanks for the answers.
Anyone know if there is a place on a Holley vac secondary where you can fill the bowls so that the car doesn't have to crank forever with the mechanical fuel pump?
Actually, in retrospect, I agree with Dean K. Just crank it to get fuel to the carb. Oil will circulate before the engine lights. I've got a brand X hot rod with a mechanical fuel pump that sits for months at a time. It gets oil pressure showing on the gauge before it fires when I crank it. I never crank the starter for more that about 10 - 15 seconds at a time so I don't overheat it.
[Re: Ramrod39]
#971027
04/13/11 02:26 AM
04/13/11 02:26 AM
Posts: 576 Hr up from KCK
451 D*O*D*G*E
Hr up from KCK
One year isnt nothing for crank and pistons long as it was good dry storage.Had a engine wipe a lifter after sitting for three though but that was a chevy derby engine who cares If you're really concerned pull dist,prime,rotate 90 degress 4 times and pull a tappet cover to look for blood
1970 Challenger R/T clone
2010 Dodge Journey R/T black,awd,
[Re: Ramrod39]
#971028
04/13/11 02:17 PM
04/13/11 02:17 PM
Posts: 370 NASHVILLE
MAVERICKSHEMI
NASHVILLE
