Changing to an aluminum intake on my 400? #970933
04/10/11 11:35 PM
04/10/11 11:35 PM
N.Wilkesboro,NC
DusterKrazy Offline OP
N.Wilkesboro,NC
I would like to swap my intake for an Edelbrock Performer 383. What all do I need? Can I reuse my intake valley pan or do I need to get a new intake valley pan plus a set of gaskets??
Re: Changing to an aluminum intake on my 400? [Re: DusterKrazy] #970934
04/10/11 11:44 PM
04/10/11 11:44 PM
florida
74fldart Offline
74fldart  Offline
florida
you can use the old pan unless its cracked , be careful in removing it and it should be ok. the factory bolts should work too. the gaskets might or might not be needed, if youve had the heads milled , the thick paper gaskets might not work, then you could use just the pan and sealer, or maybe a real thin paper gasket. ive had this problem before on an engine i dont know anything about and its trial and error as to how thick a gasket i could use .
Re: Changing to an aluminum intake on my 400? [Re: 74fldart] #970935
04/10/11 11:55 PM
04/10/11 11:55 PM
N.Wilkesboro,NC
N.Wilkesboro,NC
The heads have never been milled. So I could use the valley pan and rtv sealer if the pan is in good shape?
Re: Changing to an aluminum intake on my 400? [Re: DusterKrazy] #970936
04/11/11 06:16 AM
04/11/11 06:16 AM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
I would say NO on the REuse ...uNless you are using the same-exact total combo(heads/intake/block). And if that was the case .. it would be BESTest to use a gasket-spray on both sides of the used VP.
Re: Changing to an aluminum intake on my 400? [Re: dOoC] #970937
04/11/11 07:36 AM
04/11/11 07:36 AM
scratchnfotraction Offline
R&R the intake,reuse the vally pan
swaping on a new intake,replace the valley pan for a new seal with the intake
rtv the coners and end seals and copper spray on the runner ports
Re: Changing to an aluminum intake on my 400? [Re: scratchnfotraction] #970938
04/11/11 08:44 AM
04/11/11 08:44 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Ive reused them in the past.But at 20 bucks they are cheap.I always just use the tin.A dab of RTV in the 4 corners as said where it meets the heads and I use a thin strip where it sits on the block where the hold downs go.Just remember to not over tighten.About 25 ft pounds is good and use a criss cross pattern.Rocky
Chrysler Firepower
Re: Changing to an aluminum intake on my 400? [Re: scratchnfotraction] #970939
04/11/11 04:08 PM
04/11/11 04:08 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Personally, I don't like to reuse the VP, but in the event I do, it gets new paper gaskets (4) and all sides of those gaskets get a sealer like Indian Head Shellac.
Otherwise, the whole deal is prone to a vacuum leak.
Re: Changing to an aluminum intake on my 400? [Re: Dean_Kuzluzski] #970940
04/11/11 04:17 PM
04/11/11 04:17 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
Other than being lighter, I don't think the regular performer 383 is much better than stock.
Re: Changing to an aluminum intake on my 400? [Re: 440newport] #970941
04/11/11 06:07 PM
04/11/11 06:07 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
I had a Performer on my low deck on and off twice with the same valley pan, finally put on a Performer RPM...still the same valley pan with no issues. Been on for a couple years now
