Safe Rev Limit for 440? #970713
04/10/11 08:04 PM
04/10/11 08:04 PM
St. Charles, MO
wingman Online happy OP
Uncreative Title
wingman  Online Happy OP
Uncreative Title
St. Charles, MO
I know this question involves a ton of variables, and probably some opinion, but...
The MSD ignition 6AL box I got free only came with a 7000 pill, and I know that is too high.
The motor is a 71 block, 9.5 compression with mostly stock internals except for forged .30 over TRW pistons and good quality valves. Crank and rods appear to be stock.
I don't race the car, I just use it for cruising and fiddling around town. But with the steep gears my car has, fairly loose converter, and manual valve body, I'm afraid I'm going to miss a shift someday and be sorry.
What would be a good pill (or set of pills) to get that will keep the motor safe--but not too safe?
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Safe Rev Limit for 440? [Re: wingman] #970714
04/10/11 08:23 PM
04/10/11 08:23 PM
michigan woods
imfixinmopars426 Offline
michigan woods
std ly rod,heavy trw...=5500. or will have problems,imho...
Re: Safe Rev Limit for 440? [Re: wingman] #970715
04/10/11 08:28 PM
04/10/11 08:28 PM
San Jose, Ca.
dhkennedy Offline
dhkennedy  Offline
San Jose, Ca.
I had a 69 six pac in a 79 RC with a 5500 rev chip and that was spinning the 35s fast in the mud hitting the limit. Now I have a 75 D100 with a 78 HP that is Fast EZ-EFI limit set to 4500 and have hit it in second gear and thought that was too high for an engine that has never pistons out of the block.
Re: Safe Rev Limit for 440? [Re: dhkennedy] #970716
04/10/11 09:28 PM
04/10/11 09:28 PM
Central NC
gch Offline
gch  Offline
Central NC
You never mentioned what cam you are running.What rpm do you shift at?I would put a 6000rpm pill in it and call it a day.
Re: Safe Rev Limit for 440? [Re: gch] #970717
04/10/11 09:52 PM
04/10/11 09:52 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
I shift at 6000 and have my limiter set at 6300. I can dial mine. I don't want to run up against it. So if you're shifting at 5500 to 5800, a 6000 pill should do the trick.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: Safe Rev Limit for 440? [Re: Junky] #970718
04/10/11 10:06 PM
04/10/11 10:06 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I would also rev it to 6000 without worrying.
Re: Safe Rev Limit for 440? [Re: DaytonaTurbo] #970719
04/10/11 10:15 PM
04/10/11 10:15 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
It may stay together and may or may not even float the valves in a stock 440 at 6000 but why twist it that far when it will peak long before that and you will be far better off shifting earlier. (and easier on the motor too)
Re: Safe Rev Limit for 440? [Re: MoparforLife] #970720
04/10/11 11:16 PM
04/10/11 11:16 PM
Manitoba, Canada
Manitoba, Canada
The op hasn't said what he's got for cam and head flow, but I agree that if it's out of breath long before 6000 there's no point in taking it that high. But if it was peaking out higher in the rpm range I wouldn't sweat taking it to 6k.
Re: Safe Rev Limit for 440? [Re: DaytonaTurbo] #970721
04/11/11 12:46 AM
04/11/11 12:46 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have a stock bottom end with KB pistons and I shift at 6200. Been running it like that for years. Ron
Re: Safe Rev Limit for 440? [Re: 383man] #970722
04/11/11 07:15 AM
04/11/11 07:15 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I reved my stock bottom end 440's to 62-6300 for years and hundreds of passes. I did use good rod bolts though. Dave
Re: Safe Rev Limit for 440? [Re: quickd100] #970723
04/11/11 09:13 AM
04/11/11 09:13 AM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
Not to hijack...but do they make a 1500 pill or a 2000 pill that you can put in the MSD box....and render the engine useless when you park it somewhere....If you cant get past a low rpm....thats a pretty good theft deterrent device OR if you have kids in the house...Latter doesnt apply to me.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Safe Rev Limit for 440? [Re: Pyper70] #970724
04/11/11 11:17 AM
04/11/11 11:17 AM
Central NC
gch Offline
gch  Offline
Central NC
They make low rpm pills.YOu should be able to find one for 3000rpm.
Re: Safe Rev Limit for 440? [Re: Pyper70] #970725
04/11/11 11:28 AM
04/11/11 11:28 AM
Kirkland, Washington
Pacnorthcuda Offline
Why not just unplug the distributor connection or pull the coil wire?
Re: Safe Rev Limit for 440? [Re: Pacnorthcuda] #970726
04/11/11 11:52 AM
04/11/11 11:52 AM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
Mines a stick so I run a 6200 limiter and try to shift at 6000. Hits the limiter every once in a while. 494 - Muscle motors stroker kit, their bracket master heads. Going aluminum whenever I can figure which ones to use, botom end is stock with ARP studs.
Re: Safe Rev Limit for 440? [Re: Cudajon] #970727
04/11/11 04:49 PM
04/11/11 04:49 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I have my limiter set at 6800 on my 440.Its been well over that though.Still pulls strong when I shift.All ARP lower with studs.Been doing it for 5 years and no problems.Stockish 440 will probally be done at 5600 or less.Rocky
Chrysler Firepower
Re: Safe Rev Limit for 440? [Re: Pacnorthcuda] #970728
04/11/11 05:45 PM
04/11/11 05:45 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
Then I have to pop the hood...I have my box mounted right on top of the center console....directly behind my ashtray...I can stick my hand under there and the pill is right there....
Re: Safe Rev Limit for 440? [Re: wingman] #970729
04/11/11 06:07 PM
04/11/11 06:07 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
6000 for a stock crank ....5300 for a stroker crank...
Re: Safe Rev Limit for 440? [Re: terzmo] #970730
04/11/11 06:28 PM
04/11/11 06:28 PM
St. Charles, MO
Uncreative Title
Uncreative Title
St. Charles, MO
Thanks for all the input guys!
Re: Safe Rev Limit for 440? [Re: Pyper70] #970731
04/11/11 07:20 PM
04/11/11 07:20 PM
I put the 3,000 chip in the 'Cuda when the wife wanted to drive it to the store one time. It took her a while to tell me that she thought she broke it! LOL!
Re: Safe Rev Limit for 440? [Re: wingman] #970732
04/11/11 07:36 PM
04/11/11 07:36 PM
100 RPM less than when it lets go.
