440 crank/400 blk counterweight prob #970703
04/10/11 07:27 PM
04/10/11 07:27 PM
RapidRobert Offline OP
initial mockup; end counterweights hit the web at a diff point on each end and if they were not hitting I am not sure if the middle ones would hit or not but didn't appear to b. Should I have them all turned & if so how far? Someone had mentioned 7&1/4". Nowhere near final balancing stage & FYI LY rods/KB 280 pistons. Thank you for your time
Re: 440 crank/400 blk counterweight prob [Re: RapidRobert] #970704
04/10/11 07:32 PM
04/10/11 07:32 PM
N
NITROUSN Offline
NITROUSN  Offline
N
