Re: 1 3/4 vs 1 7/8 bb headers
[Re: jvcuda]
#970550
04/10/11 07:19 PM
04/10/11 07:19 PM
RapidRobert
1&3/4 but I'd suggest 2&1/2 or possibly 3" mandrel bends from the collector flange rearward. You would need an X pipe/proper muffs/resonators in the tailpipes alongside the leafs to keep the noise manageable esp w 3"
[Re: 383man]
#970555
04/11/11 01:12 AM
04/11/11 01:12 AM
Posts: 75,089 A Banana Republic near you.
JohnRR
All I can tell you is a run a basic 440 with KB pistons and 906 heads and I use Hedman 1-3/4 headers. Its run a best of 11.49 with them. Ron
I wonder how much faster it would go with a bigger primary header .
[Re: 383man]
#970556
04/11/11 09:51 AM
04/11/11 09:51 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
same, I think you might give up 5 maybe 10hp. My new motor is probably a tad stronger than Ron's old one and I'm still using the 1 3/4. The 1 7/8 were going to be a PITA. My mechanic friend told me to keep the small tubes, said he puts cars on the dyno all the time and usually only see a small gain. Now if you go big like 500ci or with a BIG roller cam and fully ported heads and plan on spinning it to 7k than yeah big tubes will help.
