742 rear question #970543
04/10/11 05:27 PM
04/10/11 05:27 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Is the pinion nut reverse thread or normal thread? I'm having a hell of a time busting this thing loose!!!!
THANKS!!
Re: 742 rear question [Re: mopowers] #970544
04/10/11 05:28 PM
04/10/11 05:28 PM
Kirkland, Washington
Pacnorthcuda Offline
Normal (RH) thread. A good impact should take it off.
Re: 742 rear question [Re: Pacnorthcuda] #970545
04/10/11 06:02 PM
04/10/11 06:02 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Thanks!
Re: 742 rear question [Re: mopowers] #970546
04/10/11 06:40 PM
04/10/11 06:40 PM
PA
Moparzrule Offline
Moparzrule  Offline
PA
The 742 pinion flange nut is torqued to 240 ft lbs so it will be tough but not impossible.
My
Own
Personal
Adrenaline
Rush
