Dome light door switch for a 70 E body? #97049
07/30/08 12:14 PM
07/30/08 12:14 PM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
Were can I get a 70 E body dome light switch that goes in the area in front of the doors?
Re: Dome light door switch for a 70 E body? [Re: ccdave] #97050
07/30/08 12:49 PM
07/30/08 12:49 PM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
Year One offers them under part # NG1031. Not sure if they are 'correct', but they should do the job.
(I can't remember where I bought mine from...it might have been from a vendor at the Mopar Nats a couple years ago.)
Re: Dome light door switch for a 70 E body? [Re: Blues_Cuda] #97051
07/30/08 01:38 PM
07/30/08 01:38 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
70/71 B and E bodies... maybe some other bodies too, are with 3 small pins on driver side...THEY ARE HARD TO FIND and expensive if you do.
since 72 they were changed to the regular two prongs ones.
You can change the switch for the 2 prongs kind and just need to splice two wires in to one terminal, keeping just the black wire alone what is the one that drives the driver side door ground to make work the key in buzzer and lights on buzzer.
Re: Dome light door switch for a 70 E body? [Re: ccdave] #97052
07/30/08 01:48 PM
07/30/08 01:48 PM
Monrovia, So-Cal, USA
racerhog Offline
racerhog  Offline
Napa Auto Parts ....
Bob(Cowboy)Hogan
Monrovia So-Cal
Re: Dome light door switch for a 70 E body? [Re: racerhog] #97053
07/30/08 01:56 PM
07/30/08 01:56 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
My former 1970 challenger
took these
