70 six pack throttle cable #970451
04/10/11 02:30 PM
04/10/11 02:30 PM
Owosso, Michigan
stateroadhog Offline OP
Owosso, Michigan
HELP I have 70 b-body that I'm installing six pack set-up. The throttle cable that came in install kit appears to be for 71 and up and I see no listings for a 70 B-body six pack throttle cable. Will the 69 1/2 work or what one will work?
Re: 70 six pack throttle cable [Re: stateroadhog] #970452
04/10/11 02:53 PM
04/10/11 02:53 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
69 1/2 will work if you can find one. the one you have is for 70 thru 340-6 or 71 and up 440
Re: 70 six pack throttle cable [Re: stateroadhog] #970453
04/10/11 04:32 PM
04/10/11 04:32 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Year One,...NORS cables pn# FD9339 $55, it's for a 68-70 b-body 440 4 bbl listing, but I've used it on my 70 Charger 440/6 with no issuses,...I've seen no 440/6 applications avaliable either, the MP install kits seem to only have the E body and 71-up cable, leaving the early B bodies out
Mike
Re: 70 six pack throttle cable [Re: DAYCLONA] #970454
04/11/11 12:24 AM
04/11/11 12:24 AM
Adrian, Mi
P
pro6pakRR Offline
mopar addict
pro6pakRR  Offline
mopar addict
P
Adrian, Mi
Mine has the stock 383 cable.Going to a /6 truck cable .
Re: 70 six pack throttle cable [Re: pro6pakRR] #970455
04/11/11 01:45 PM
04/11/11 01:45 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have had everything from a single 4 BBl to a 440 sixpack to a dual 4 BBl 426 Hemi in one of my 70's & all worked fine with the stock 440 4 BBl throttle cable.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: 70 six pack throttle cable [Re: DAYCLONA] #970456
04/11/11 02:08 PM
04/11/11 02:08 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Yeah, I ended up using my original but the 440-4 one looked like it would work.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: 70 six pack throttle cable [Re: DPelletier] #970457
04/11/11 07:49 PM
04/11/11 07:49 PM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
so the mp install kit i ordered in feb and just received today throttle cable won't work?
Re: 70 six pack throttle cable [Re: meepmeep70] #970458
04/11/11 08:25 PM
04/11/11 08:25 PM
Owosso, Michigan
Owosso, Michigan
not on a 70 and back B-body, but I was told that you can file the corners of the round hole to square it up and it will work. This came from Ben at Pro Maxx.
Re: 70 six pack throttle cable [Re: stateroadhog] #970459
04/12/11 04:46 PM
04/12/11 04:46 PM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
thank you for that tip,other then that the length is good,just where it goes into firewall needs attention?
Re: 70 six pack throttle cable [Re: stateroadhog] #970460
04/13/11 09:47 AM
04/13/11 09:47 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I used a stock 383 4bbl cable and it worked fine on my 6-pack.
Coming soon!!!!
