msd 12 volt switched source question #970395
04/10/11 01:12 PM
04/10/11 01:12 PM
Lincoln NE
440forPOWER Offline OP
super gas
super gas
Lincoln NE
Stupid ? but can the small lug on the starter relay be used for the 12 volt switched source? Thanks
Re: msd 12 volt switched source question [Re: 440forPOWER] #970396
04/10/11 01:17 PM
04/10/11 01:17 PM
'mornin Tim, I missed you in Church today . The yellow "ign" wire would be only b hot while cranking
Re: msd 12 volt switched source question [Re: 440forPOWER] #970397
04/10/11 01:27 PM
04/10/11 01:27 PM
N
NITROUSN Offline
NITROUSN  Offline
N
You cant use the yellow wire. Once running the circuit would be fed from the run side keeping the relay engaged.
Re: msd 12 volt switched source question [Re: NITROUSN] #970398
04/10/11 01:42 PM
04/10/11 01:42 PM
excellent point, that would definitely b a prob
Re: msd 12 volt switched source question [Re: RapidRobert] #970399
04/10/11 01:52 PM
04/10/11 01:52 PM
Lincoln NE
super gas
super gas
Lincoln NE
Morning Robert, I was there saving you a seat
Re: msd 12 volt switched source question [Re: 440forPOWER] #970400
04/10/11 01:55 PM
04/10/11 01:55 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i had to delete my first post and walk out and look. my constant power source is off the bat side of the relay. the 'switched' power i have running of the coil feed.
Re: msd 12 volt switched source question [Re: 440forPOWER] #970401
04/10/11 02:00 PM
04/10/11 02:00 PM
Yeah I was afraid of that. You know I never was a good poker player & I was on Moparts all morning and I hope the big guy understands
Re: msd 12 volt switched source question [Re: 440forPOWER] #970402
04/10/11 05:21 PM
04/10/11 05:21 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
For a switched source for the MSD simply eliminate the ballast resister and splice the wires on both sides of it together and use the original coil (+) wire as the switched source.
Or you can leave the ballast in position and use the coil (+) wire as a switched source; the MSD doesn't care about the voltage in the switched wire, it merely turns the unit on/off.
