A-body console and aftermarket shifters #970243
04/10/11 03:41 AM
04/10/11 03:41 AM
Metro Detroit
1970RT Offline OP
1970RT  Offline OP
Metro Detroit
I'm thinking about picking up an aftermarket automatic shifter and would like to know if anyone knows of any that will fit under/in a factory A-body console? I have been looking at various shifters and kind of like the looks of either the Hurst Pro Matic or B&M Quicksilver shifters in particular. Has anyone used either of these shifers with a factory console? If so, did you have to modify the console at all and if you did, how so?
Re: A-body console and aftermarket shifters [Re: 1970RT] #970244
04/10/11 10:54 AM
04/10/11 10:54 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Here's my solution (1970 slapstick with an A-body knob - the effective length of the upper arm on the down shaft needs to be shortened to 2-1/4" from 2-1/2):
Re: A-body console and aftermarket shifters [Re: 1970RT] #970245
04/10/11 10:52 PM
04/10/11 10:52 PM
Metro Detroit
1970RT Offline OP
1970RT  Offline OP
Metro Detroit
Re: A-body console and aftermarket shifters [Re: 1970RT] #970246
04/10/11 11:02 PM
04/10/11 11:02 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Never done it myself but I have seen some nice ones. I say get your quick silver and make it work. It should pop up through the original slot and look pretty nice. If all else you could mount the one with a boot on top of your counsel but I do believe it will fit rather nicley inside. Like I said I have seen 'em and they look nice. Might not be a strict bolt in but it is doable. Not origanal so don't be affraid to modify or fabricate. Then you can show us all how it is done.
Re: A-body console and aftermarket shifters [Re: bboogieart] #970247
04/14/11 12:10 AM
04/14/11 12:10 AM
Metro Detroit
1970RT Offline OP
1970RT  Offline OP
Metro Detroit
One more try. Some of you A-body guys must have done this.
Re: A-body console and aftermarket shifters [Re: 1970RT] #970248
04/14/11 10:19 AM
04/14/11 10:19 AM
...gently down the stream
LAR_414 Offline
LAR_414  Offline
I modified my console and put a Hurst Promatic V Ratchet shifter under it. Worked great and looked great,....was in 4 magazines this way. I always got cool comments from this setup.
I'm thinking of selling the Console (and carpet) if you are interested. Idon't have the shifter anymore.
Re: A-body console and aftermarket shifters [Re: 1970RT] #970249
04/14/11 10:40 AM
04/14/11 10:40 AM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
We're in the process of doing this to my Duster right now. I'll get pics when it's finished.
Re: A-body console and aftermarket shifters [Re: dustergirl340] #970250
04/14/11 08:16 PM
04/14/11 08:16 PM
Lyons, CO
MileHighDart Offline
Lyons, CO
I've seen pics of this done on abodys.
You could go over to forabodiesonly dot com, and do a search.
I was thinking of doing this as well. I just installed the Hurst promatic2 in my car, but haven't found a nice console yet.
Or I've considered building my own console around the new shifter. Not sure which way I'll go yet.
Re: A-body console and aftermarket shifters [Re: 1970RT] #970251
04/15/11 10:52 AM
04/15/11 10:52 AM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
Why not use a Autogrip?
Its a pistol grip handle for your automatic.
Check the link in my sig pic.
