Erson Ductile Iron Rockers B/RB Rocker Shafts #970187
04/10/11 01:01 AM
04/10/11 01:01 AM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
I bought a set of big block Erson ductile iron rockers from a Moparts member, but I can't find them anywhere online. I assume they've been discontinued. Does anyone know what size rocker shafts I'm supposed to use with these? Will the standard crane shafts for their ductile iron rockers work?
Re: Erson Ductile Iron Rockers B/RB Rocker Shafts [Re: GTX MATT] #970188
04/10/11 01:28 AM
04/10/11 01:28 AM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Yes, they are disco'ed....
What is the ID of the rockers you have?
If they take something other than a standard OD shaft, give RAS a call. They can probably get you taken care of.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Erson Ductile Iron Rockers B/RB Rocker Shafts [Re: GTX MATT] #970189
04/10/11 08:50 AM
04/10/11 08:50 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
My Sig Ersons I bought in 71 fit the stock shafts.Ive run them for 40 years and only had to replace the adjusters.I used MP adjusters and locks.Rocky
Chrysler Firepower
Re: Erson Ductile Iron Rockers B/RB Rocker Shafts [Re: GTX MATT] #970190
04/10/11 02:15 PM
04/10/11 02:15 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I think they require a hard chrome shaft to reduce gualing. If it were me, I would send them to RAS and have them gone over and matched to a fresh set of shafts.
