1964 4 spd speedometer gears #970127
04/09/11 10:37 PM
04/09/11 10:37 PM
WI
W
wannadrag Offline OP
W
WI
1964 Belvedere with a original 64 type 4 spd,4.10 gears with a 28" tire.Speedometer is way off.What do i need to do to make the speedometer accurate?
Re: 1964 4 spd speedometer gears [Re: wannadrag] #970128
04/09/11 10:48 PM
04/09/11 10:48 PM
Northern MN
1E2C Offline
1E2C  Offline
Northern MN
A miracle. Seriously, they didn't make a gear to go with that ratio, you need an adapter. I've heard Imperial Services makes one, but can't swear to it. Here's a chart of tire sizes vs rear ratio, this will let you calculate the adapter ratio.
Mike
Re: 1964 4 spd speedometer gears [Re: 1E2C] #970129
04/10/11 08:54 AM
04/10/11 08:54 AM
Palmyra, NY
63stabamatic Offline
Palmyra, NY
I couldn't find the right gear for my pushbutton 63 trans so ended up with a GPS heads up speedometer that puts the speed on the windshield. It was half the price of the gear adapter which would only be good for that tire and gear.
Re: 1964 4 spd speedometer gears [Re: 1E2C] #970130
04/10/11 08:55 AM
04/10/11 08:55 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Steve at Imperial Services makes an adapter that changes the ratio.They are pricey.When I had the 4.88s in my 65 the speedo would show 80 in first.I have 3,91s now and know that the speedo is off by about 20 %.I just go by that.Rocky
Chrysler Firepower
