disc brake swap #970025
04/09/11 06:50 PM
04/09/11 06:50 PM
OHIO U.S.A.
DUSTER51 Offline OP
DUSTER51  Offline OP
OHIO U.S.A.
I have a 72 duster 340 with 10 inch front drum brakes I replaced them with a factory k.H. disc set up changed the lower ball joints and spindles . do I need to change the master cylinder and proportioning valve or any other parts ?
Re: disc brake swap [Re: DUSTER51] #970026
04/09/11 07:21 PM
04/09/11 07:21 PM
Middle River, MD
Mapandjlp Offline
Mapandjlp  Offline
Middle River, MD
I bought a new disc brake master cylinder and used the original drum/drum prop valve when I converted my '70 Challenger from 10" drum to manual discs. It works fine.
Re: disc brake swap [Re: DUSTER51] #970027
04/09/11 07:31 PM
04/09/11 07:31 PM
Stick a drill bit deep into the M/C brass conical seat closest to the firewall (that you hooked to the front discs) & if there's no RPV (it's spongy, you'll feel it) in there you are good. I added 74 A discs/10" rear drums to a '65 dart that had OE 4 wheel 9" drums & kept the OE drum splitter & no probs. (proportioning is OK & no excessive front pad wear). Not the way it is recommended but I was in a hurry & didn't want to mess w reflaring lines at the time so I didn't know what to expect
Re: disc brake swap [Re: Mapandjlp] #970028
04/10/11 08:58 AM
04/10/11 08:58 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Just get a master for a 69 or so C body with discs.Ive done several and never any problems.I run one on my 65 B and my kids 62 300.Rocky
Chrysler Firepower
