Removing stuck pistons/rods #970017
04/09/11 06:47 PM
04/09/11 06:47 PM
near St Petersburg, FL
Lifsgrt Offline OP
Lifsgrt  Offline OP
What is the best way to remove pistons and rods from an engine that is seized from sitting? I have a 383 that I want to tear down but save the rods for possible future use. Is there a way to do this without damaging the rods? Thanks.
B3 1969 Charger R/T SE, 440/727 with 3:91s running 11.07@120
Re: Removing stuck pistons/rods [Re: Lifsgrt] #970018
04/09/11 06:50 PM
04/09/11 06:50 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
soak the piston holes with brake fluid... KRIOL or Marvel Mystery oil works well to but is more expensive...
I am truckless..
Re: Removing stuck pistons/rods [Re: Lifsgrt] #970019
04/09/11 06:58 PM
04/09/11 06:58 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
Is the crank in there too ?
Re: Removing stuck pistons/rods [Re: dOrk !] #970020
04/09/11 07:07 PM
04/09/11 07:07 PM
Lifsgrt Offline OP
Lifsgrt  Offline OP
Yes, crank still installed. Last time I tried this on an engine I banged up a couple of rods and nicked the crank. Is there a way to break the pistons to release the pins without hurting the block or rods?
Re: Removing stuck pistons/rods [Re: Lifsgrt] #970021
04/09/11 07:10 PM
04/09/11 07:10 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
So you are not saving the crank?
Re: Removing stuck pistons/rods [Re: dOrk !] #970022
04/09/11 09:59 PM
04/09/11 09:59 PM
Lifsgrt Offline OP
Lifsgrt  Offline OP
I must be a terrible communicator. I have a 383 with the pistons stuck on the rods, in the cylinders, crank is still installed. I'll call it a shortblock. I want to tear the engine down while saving the rods, crank, and block. Last time I tried this on a 440, the pins were seized in the pistons, and the rods wouldn't pivot on the pins, which will not allow the piston to be pushed/driven up into the cylinders. I bent up a couple of rods and nicked the crank. Thought maybe someone on here would have the answer, short of hot-wrenching the rods. Anyone?? Bueller?? Thanks
Re: Removing stuck pistons/rods [Re: Lifsgrt] #970023
04/09/11 10:02 PM
04/09/11 10:02 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
Just clarify what choo want .....
Do you have an engine stand that will rotate ?
Re: Removing stuck pistons/rods [Re: dOrk !] #970024
04/09/11 10:41 PM
04/09/11 10:41 PM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
KRIOL will do the trick spray the top and left it soak in.Then do it from the bottom.Couple times a day for a few days.Be patient.A few hits with a deadblow hammer on the pistons should finish loosening them.You may need to sleeve a few holes if they are rusted too bad.
Leave the gun.......take the Cannoli's....Mike
