Cleaning rust from lifter bores #969830
04/09/11 12:14 PM
04/09/11 12:14 PM
Space Station #5
471Magnum Offline OP
Space Station #5
Getting into the assembly phase of my small block stroker. There is some light rust in the lifter bores that I need to remove. What's the best method to clean these out? Can't seem to find a wire brush that will fit the bore. Maybe a scouring attachment for my dremel?
Yes, I'll definitely make sure the lifters spin freely before I assemble.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: Cleaning rust from lifter bores [Re: 471Magnum] #969831
04/09/11 12:16 PM
04/09/11 12:16 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
Get a little dingle berri hone brush
Re: Cleaning rust from lifter bores [Re: dOrk !] #969832
04/09/11 12:29 PM
04/09/11 12:29 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Yup, brake cylinder hone.. Don't get the spring loaded type it won't work, dingle berry hone...
Re: Cleaning rust from lifter bores [Re: dOrk !] #969833
04/09/11 12:31 PM
04/09/11 12:31 PM
Kirkland, Washington
Pacnorthcuda Offline
A 10 gauge shotgun brush might work if you can find one.
10 gauge is .77 bore (much smaller than the .904 lifter bore but they are over size brushes in order to scour the bore.
Might be large enough if the rust is VERY light.
Re: Cleaning rust from lifter bores [Re: 471Magnum] #969834
04/09/11 12:59 PM
04/09/11 12:59 PM
Space Station #5
Space Station #5
Okay. Next question.
Looks like O'Reilly stocks a 7/8". I'm guessing that size will work.
Next size up is a 1" which would be a bit over size.
-Jim
Re: Cleaning rust from lifter bores [Re: 471Magnum] #969835
04/09/11 01:18 PM
04/09/11 01:18 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
You want it slightly oversize so the wires supporting the berries deflect a little... With a small hone you won't get even pressure... 15/16 would be ideal & they do/did make them, I have one from back in the 80's... But a 1" will work just don't do more than a couple passes with it.. Use light oil & expect to be cleaning the block again...
Re: Cleaning rust from lifter bores [Re: 471Magnum] #969836
04/09/11 01:32 PM
04/09/11 01:32 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Unlike piston rings that need a perfect bore to seal, lifters only need a clean bore to ride in. That said, just give them a couple passes to get rid of surface rust. Any deep pits will not affect the lifter. The last thing you want to do is make the bores bigger!
Re: Cleaning rust from lifter bores [Re: Stanton] #969837
04/09/11 01:35 PM
04/09/11 01:35 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Re: Cleaning rust from lifter bores [Re: 471Magnum] #969838
04/09/11 01:38 PM
04/09/11 01:38 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Try a copper tubing wire brush. They make a few sizes and I think there is one size that works pretty well. They are $3.00 at the local hardware store. Cut off the handle end and chuck it up in your cordless if you like.
Re: Cleaning rust from lifter bores [Re: Stanton] #969839
04/09/11 01:41 PM
04/09/11 01:41 PM
Space Station #5
Space Station #5
I haven't searched really aggressively, but from what I've found, they seem to jump from 7/8" to 1" with nothing in between. Some places jump from 7/8" to 1 1/4". It would seem to me that you'd want just a little interference to truly hone. That said, for removing rust, 7/8" is probably the way to go.
Re: Cleaning rust from lifter bores [Re: 471Magnum] #969840
04/09/11 02:57 PM
04/09/11 02:57 PM
East Brunswick, NJ
finadk Offline
finadk  Offline
East Brunswick, NJ
I used the "safest rust remover" to clean up a machined block that I left for too long. Works great to remove the rust then a light clean up with the hone.
Scott
Scott 1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed) 2002 Dodge Ram 1500 Quad Cab 1976 Corvette
Re: Cleaning rust from lifter bores [Re: 471Magnum] #969841
04/09/11 03:48 PM
04/09/11 03:48 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
lets see ...
7/8 = 0.875
chrysler lifter bore = 0.904
1" = 1.00
I've run a small 3 leg brake cylinder hone in a lifter bore just to remove any high spots after having a block shotpeened with no ill affects .
Re: Cleaning rust from lifter bores [Re: JohnRR] #969842
04/09/11 04:17 PM
04/09/11 04:17 PM
Space Station #5
Space Station #5
Little buggers are proving to be quite elusive. Can't seem to find any store in town that has one in stock.
Harbor Freight has a three stone job in stock (cheap too):
http://www.harborfreight.com/1-1-8-eighth-inch-brake-cylinder-hone-97163.html
-Jim
Re: Cleaning rust from lifter bores [Re: 471Magnum] #969843
04/09/11 07:45 PM
04/09/11 07:45 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Go with the HF 3-stone job but just do one quick pass down, up and out. Those things take off a lot of material
Re: Cleaning rust from lifter bores [Re: Stanton] #969844
04/09/11 08:22 PM
04/09/11 08:22 PM
Space Station #5
Space Station #5
I found a set of brushes at Harbor Freight that did the trick.
Re: Cleaning rust from lifter bores [Re: 471Magnum] #969845
04/09/11 10:53 PM
04/09/11 10:53 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
The three stone type have been known to grab the oil galley & self destruct... DAMHIK...
Re: Cleaning rust from lifter bores [Re: dOrk !] #969846
04/10/11 11:21 AM
04/10/11 11:21 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
that's PRICELESS!!!! you're killing me over here let me track down my cat, he's always got a few stuck back there!
Re: Cleaning rust from lifter bores [Re: 1_WILD_RT] #969847
04/10/11 11:24 AM
04/10/11 11:24 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I'm not condoning it's use just saying it could be done if you are real careful.
What I was trying to point out to the OP was that trying to clean a .904 bore with a .875 hone is going to be futile .
Re: Cleaning rust from lifter bores [Re: JohnRR] #969848
04/10/11 01:15 PM
04/10/11 01:15 PM
Space Station #5
Space Station #5
It's all moot now. The 1" steel brush from HF with a little PB Blaster cleaned the up real nice.
-Jim
