Hurst Shifter #969765
04/09/11 08:29 AM
04/09/11 08:29 AM
Central Pa. U.S.A.
Bigfury Offline OP
Bigfury  Offline OP
Central Pa. U.S.A.
Would it be possible to install a long arm (B-body) shifting mechanism in E-body with a regular pistol grip? Trying to achive a shorter shifting pattern.How much hecking would need to be done to the cross member? Is it difficult to fabricate the shifting rods?All this being said is it worth the hassle or am I just pi$$ing in the wind?
Thanks in advance. Just love this forum
Re: Hurst Shifter [Re: Bigfury] #969766
04/09/11 10:37 AM
04/09/11 10:37 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
I don't see why you would have to do any of the mods you are talking about unless the shifter rods are almost touching the crossmember now . Good point you bring up though as I am going to be doing the same thing in my Dart GTS , I guess you could just cut a small notch for clearance ?
