5.7 hemi swap issue #969725
04/09/11 04:11 AM
04/09/11 04:11 AM
Memphis, MO
X
xpsyclonex2002 Offline OP
X
Memphis, MO
I've swapped a 2005 5.7 truck motor into my 66 coronet. I am having trouble getting it to run though. The motor turns over and starts if I use a blast of starting fluid but it only idles roughly for about 20-30 seconds then shuts off. I think that it might be an anti theft issue but I was told that the anti theft shuts it down faster than that and the computer that I am using is from a 2004 5.7 truck with manual transmission. I was told that the 2004's didn't have the anti theft. any ideas? I did check the fuel pressure and I am at about 53+/- psi. I am using the corvette fuel filter regulator and a walbro in tank fuel pump
Re: 5.7 hemi swap issue [Re: xpsyclonex2002] #969726
04/09/11 11:43 AM
04/09/11 11:43 AM
upstate NY
batt2rm Offline
batt2rm  Offline
upstate NY
Just a possibility do you have power to the computer when in the run position. Found that I had a bad ignition switch, put new switch in a connected both the start and run wire leads together and took care of problem.
Re: 5.7 hemi swap issue [Re: batt2rm] #969727
04/09/11 11:51 PM
04/09/11 11:51 PM
Memphis, MO
X
X
Memphis, MO
anybody else got any ideas?
Re: 5.7 hemi swap issue [Re: xpsyclonex2002] #969728
04/10/11 12:15 AM
04/10/11 12:15 AM
Dayton, Ohio
W
wldtm Offline
wldtm  Offline
W
Dayton, Ohio
pretty sure SKIM theft system can cause a start and die. Usually, they start and die 5-6 times, then nothing at all ( i think). The only way to know for sure would be to use a scan tool to see if the theft system is indeed activated.
I dont think, 04 computers did not have SKIM just because it was an 04. Or use an anoid light to check and see if the injectors quit pulsing when the car quits running.
Interested in having you car wired? Drag car, street car, EFI swap? PM for details
