Re: Is there a heat-reflective paint for intake manifolds?
[Re: BradH]
#969274
04/08/11 04:58 PM
04/08/11 04:58 PM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
I used this adhesive backed insulation on the underside of my intake. You can't see it once installed. It's easy to use, inexpensive and works great. http://www.thermotec.com/products/13500-adhesive-backed-heat-barrier.html
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: HEMIFRED]
#969276
04/08/11 05:03 PM
04/08/11 05:03 PM
Posts: 30,451 Florida STAYcation
dOoC
The village idiot's idiot
Florida STAYcation
Just do what the montgomery county police did with their RB stuff and put insulation between the manifold and the valley tray...
THE FACTORY DID THAT IN THE 60'S
That was done for "sound" .. not to "insulate" anything. IN FACT ... since it blocked the air-flow from uNder the intake .. it actually made the intake warmer.
