8 3/4 center section ? #969222
04/08/11 11:32 AM
04/08/11 11:32 AM
Lost and Spaced
bboogieart Offline OP
Lost and Spaced
My 68 Chrysler is leaking from the pinion seal.
I have the drive train out so now is the time to fix it. I have seen this a couple places lately. The general concesous is to measure the break away torque first. I just read in a mopar mag that this is only needed in the 489 cases. 741 and 742 supposedly do not have a crush sleeve. Anyone know for sure what is in my New Port? It is the 68 741.
Thanx.
Re: 8 3/4 center section ? [Re: bboogieart] #969223
04/08/11 11:41 AM
04/08/11 11:41 AM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
Preload is needed in 489s, just zip your pinion nut off and replace the seal in your 741.
Ride eternal, shiny and chrome
Re: 8 3/4 center section ? [Re: DirectSubjection] #969224
04/08/11 11:48 AM
04/08/11 11:48 AM
Lost and Spaced
Lost and Spaced
This is what I was looking for thank you.
Re: 8 3/4 center section ? [Re: bboogieart] #969225
04/08/11 11:54 AM
04/08/11 11:54 AM
Youngsville, NC
dem440c Offline
dem440c  Offline
Youngsville, NC
there is a torque value for the pinion nut, I can't seem to commit it to memory but it will be in the shop manuals if you have one. I can check it when I get home from work if no one else chimes in before then
Re: 8 3/4 center section ? [Re: dem440c] #969226
04/08/11 11:57 AM
04/08/11 11:57 AM
Lost and Spaced
Lost and Spaced
Thanx I was mainly concerned about the crush sleeve.
Re: 8 3/4 center section ? [Re: dem440c] #969227
04/08/11 01:23 PM
04/08/11 01:23 PM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
240 ft lbs. min.
