Mini - Tub Help #969201
04/08/11 10:40 AM
04/08/11 10:40 AM
Stow ,Ohio
demon440 Offline OP
demon440  Offline OP
Stow ,Ohio
Anybody in the Cleveland/Akron Ohio area.
I need to mini-tub my Demon.
I don't have a welder.
Help !!!
Re: Mini - Tub [Re: demon440] #969202
04/08/11 10:59 AM
04/08/11 10:59 AM
mass
K
kotacars Offline
kotacars  Offline
K
mass
A professional mini tub job will run you 1000 dollars.
Re: Mini - Tub [Re: kotacars] #969203
04/08/11 11:32 AM
04/08/11 11:32 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Indianapolis to far?
Re: Mini - Tub [Re: demon440] #969204
04/08/11 11:49 AM
04/08/11 11:49 AM
organ
maximum entropy Offline
organ
if you remove the stock wheelhouses, you'll need to put a cage in it. the stock wheelhouses are structural elements, and your car will fold in half without 'em. i'm pretty sure the stock ones can be widened without having to add a cage.
Re: Mini - Tub [Re: demon440] #969205
04/08/11 12:18 PM
04/08/11 12:18 PM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
Try Bob, at Profab, he's a member on here
Re: Mini - Tub [Re: B1KILLER] #969206
04/08/11 12:36 PM
04/08/11 12:36 PM
Stow ,Ohio
demon440 Offline OP
demon440  Offline OP
Stow ,Ohio
Indy is too far,
Looking for someone somewhat local.
I tried Bob before,he was busy.
Any local guys want to come over and help me
and make a couple bucks?
Re: Mini - Tub [Re: maximum entropy] #969207
04/08/11 12:56 PM
04/08/11 12:56 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I'll disagree with that...My 71 Demon has had he OEM tubs cut out and steel chassis shop tubs installed.Not welded to the car at all and I have a roll bar that has the rear down braces end where the back seat is.Car has been this way since 1981 and no problems with the body at all,and it hooks great.
Nautilus Racing-
Re: Mini - Tub [Re: Chris2581] #969208
04/08/11 01:08 PM
04/08/11 01:08 PM
Ripley
BryanRad Offline
BryanRad  Offline
Ripley
Would be interested in doing it for you, here is how we do ours. Basically just extend the tub to the frame rail.
Re: Mini - Tub [Re: Chris2581] #969209
04/08/11 01:08 PM
04/08/11 01:08 PM
organ
organ
Re: Mini - Tub [Re: maximum entropy] #969210
04/09/11 10:51 PM
04/09/11 10:51 PM
Ripley
BryanRad Offline
BryanRad  Offline
Ripley
Another
Re: Mini - Tub [Re: BryanRad] #969211
04/09/11 10:53 PM
04/09/11 10:53 PM
Ripley
BryanRad Offline
BryanRad  Offline
Ripley
Another.
Re: Mini - Tub [Re: BryanRad] #969212
04/09/11 10:54 PM
04/09/11 10:54 PM
Ripley
BryanRad Offline
BryanRad  Offline
Ripley
Last one.
Re: Mini - Tub [Re: BryanRad] #969213
04/11/11 02:23 AM
04/11/11 02:23 AM
Stow ,Ohio
demon440 Offline OP
demon440  Offline OP
Stow ,Ohio
Looks good.
I know how to do it, but I don't have a welder.
Where are you located?
Any chassis shops in Cleveland/Akron area?
