tire tube ? #969196
04/08/11 09:29 AM
04/08/11 09:29 AM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
MT 30-12.50-15. im going to put tubes in them,its a street strip deal.how much will the tire actually move on the rim or is it even somthing im need to worry about.heavy B-body,good hook.
Re: tire tube ? [Re: bonefish] #969197
04/08/11 10:29 AM
04/08/11 10:29 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Would depend on what your tire pressure is
Re: tire tube ? [Re: MR_P_BODY] #969198
04/08/11 11:27 AM
04/08/11 11:27 AM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
i still have to experiment with that,if i do have to screw it is their a prob with just doing the inside of the rim?this car should only be in the high 10 sec range but it does hook good.
Re: tire tube ? [Re: bonefish] #969199
04/08/11 11:37 AM
04/08/11 11:37 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Screwing one side is a BAD idea... IF the tire turns it
tends to pull the non screwed side in and will pull
it off the rim... if you dont want to screw the rims
you would be better off not running tubes... just soap
the inside of the tire if you have a air loss issue
Re: tire tube ? [Re: MR_P_BODY] #969200
04/08/11 02:01 PM
04/08/11 02:01 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
I've always run tubes and screws. Helps your sidewall life.
