distributor #96904
07/30/08 07:48 AM
07/30/08 07:48 AM
michigan
70 buzz Offline OP
70 buzz  Offline OP
michigan
I have my original distributor and wanting to restore the thing. It is really a mess in appearance. Can I bead blast it and the brass tag to bring it back or is that a bad Idea? Thanks
Re: distributor [Re: 70 buzz] #96905
07/30/08 08:41 AM
07/30/08 08:41 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
If you bead blast it without "COMPLETELY" dissembling it you can have problems.If it is a dual point Prestolite you will end up with glass beads in the breaker plate bearings .Also,there is a felt wick behind the oil filler,you will also have glass beads there.If you remove everything and rinse it with a good solvent and blow it dry you shouldn't have a problem.Also,the tag is aluminum not brass.
If you have a Chrysler distributor,same precautions.
Re: distributor [Re: 62maxwgn] #96906
07/30/08 02:22 PM
07/30/08 02:22 PM
michigan
70 buzz Offline OP
70 buzz  Offline OP
michigan
Ok! Here is the the distributor. What does the tag number tell me? What is the best way to restore this? I think it is the original one to my 70 Super Bee but not sure. Thanks
Re: distributor [Re: 70 buzz] #96907
07/30/08 02:28 PM
07/30/08 02:28 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
Hi, Your distributor part is correct for 70 383-4 barrel with auto or manual trans. The 8 0 is for 8th week of 1970 or end of february beginning of March. Your car was likely built in March of 70 or later if this is the original.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: distributor [Re: 70gtx440dana] #96908
07/30/08 09:34 PM
07/30/08 09:34 PM
michigan
70 buzz Offline OP
70 buzz  Offline OP
michigan
the built date on the car is 12-05-69
