stroker or stock stroke ????? sb 360
#969048
04/08/11 12:27 AM
04/08/11 12:27 AM
Posts: 1,390 CA.
RAY1969CARS
CA.
im about to buy a new crank and not sure the steel scat cranks are the same price ??? 360 w5 heads not ported yet mp m1 large runner 950 holley/proform no pistons yet want to be around 12 t0 1 or 13 but well be ross 17/8 hookers no cam thinking around 620 260 roller 1.5 rocker a/m trans 430/456 not sure ??? 29 tire will be running nos 150 shot please feel free to have input on parts im not sur of thanks ! mopar or no car p.s. what are the rpm dif withe the chank ???
Re: stroker or stock stroke ????? sb 360
[Re: RAY1969CARS]
#969049
04/08/11 12:46 AM
04/08/11 12:46 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Stroke it.... your engine is pretty close to mine... 416(340 base) 4" stroke, .620 lift roller, 11.1 compression(diamond pistons) W-5 heads(ported), M-1 large runner intake, and either a 1050 dom or a 850... 518 auto with OD, a 5000 stall, 4.10 or 4.30 gear and 30" QTP
[Re: MR_P_BODY]
#969050
04/08/11 01:39 AM
04/08/11 01:39 AM
Posts: 1,390 CA.
RAY1969CARS
CA.
what about rpm what would it spin to ??? who ported your heads ??? how much hp do you think ???p.s im running scat i beams
[Re: RAY1969CARS]
#969051
04/08/11 02:03 AM
04/08/11 02:03 AM
MR_P_BODY
With the duration that I am running(260/270) I will only turn 7000 ... I ported my own when I was still working at Chrysler so I had a flow bench to test with... I will guess at 525-550hp... I'm sure I can make more with some different parts but these parts are what I have laying around the shop... I had a 4" crank and a set of Eagle H-beams, have a few 340 blocks, I had the cam, I bought new roller lifters and I bought new pistons... all my other pistons I have are big compression stuff(and I had 3 sets of new pistons)
[Re: RAY1969CARS]
#969052
04/08/11 02:11 AM
04/08/11 02:11 AM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
4" crank would be nice. Alot of power for a stock block though.... Maybe keep the rpm down. Or a 4.125 K1 crank...lots of options! Brian
Brian Hafliger
