Re: firing a new 360 question
[Re: coronetkid]
#968838
04/07/11 09:58 PM
04/07/11 09:58 PM
Posts: 1,443 Maryland
Dads426
Maryland
After prelubing, if you don't have the stock timing specs I would start with 6-10 degrees advanced. Turn the crank so the timing mark is at the 6 or 10 degree advanced timing mark. With the dist cap off rotate the base of the distributor until the reluctor (metal part in pickup) lines up with one of the vanes on the rotor. Be sure the dist rotor is lined up with number one plug wire. Fire and go.
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
[Re: Dads426]
#968839
04/07/11 10:36 PM
04/07/11 10:36 PM
Posts: 509 Middle River, MD
Mapandjlp
Middle River, MD
[Re: coronetkid]
#968840
04/07/11 10:41 PM
04/07/11 10:41 PM
RapidRobert
tomorrow i will be starting a basically stock rebuilt LA360.
turn crank to 10BTDC, line up reluctor tooth w the magnet, if you set the timing chain/gears are at dot to dot (12 & 6 o'clock) have rotor under #6 plug wire, vac adv capped, dist clamp lightly snugged. When it fires & you bring the RPM up have a helper turn dist to immed get 35 (dialback or 2.214" is 35 deg). Read "breakin secrets" at www.mototuneusa.com. thermostat out, shop fan in front of rad, a helper to add trans fluid, a helper to spot leaks, you in the dr seat to monitor the gauges/shout orders. 4 or 5 pumps of fuel/charged batt/trans in neutral. Goose the throttle many times (from 2500 to higher) during the 25-30 minutes, pour some zinc additive in the oil
