69 RR, steering column loose/up/down in car, help?? #968650
04/07/11 05:52 PM
04/07/11 05:52 PM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
The steering column shaft in my 69 RR has come loose. Basically you can pull it towards you maybe an inch which then causes a lot of up/ down freeplay on the shaft assy. I rebuilt/restored my steering column myself and and I'm nervous I didn't do something right. I had a problem with the sheer pins melting during powder coating (I'll never do that again..) but I replaced them with similar plastic pins/screw from lowes like was recommended on here. The shaft is moving inside the column between the firewall and the wheel, cause in the eng compartment the shaft doesn't move when you wiggle it inside. My steering column is a manual steering 4spd version. I didn't have this problem until after a few hundred miles on the car, but the 255/17s and manual steering cause a lot of ummph on the wheel at times. I could really use some help on what may be causing this.
Re: 69 RR, steering column loose/up/down in car, help?? [Re: NV69B7RR] #968651
04/07/11 09:30 PM
04/07/11 09:30 PM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
NE1?
Re: 69 RR, steering column loose/up/down in car, help?? [Re: NV69B7RR] #968652
04/07/11 09:54 PM
04/07/11 09:54 PM
CrazyD Offline
CrazyD  Offline
Top snap ring may have come off, allowing shaft to drop. Look at service manual for assembly diagram.
Re: 69 RR, steering column loose/up/down in car, help?? [Re: CrazyD] #968653
04/08/11 12:14 AM
04/08/11 12:14 AM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
I will check that, thanks for the reply.
Re: 69 RR, steering column loose/up/down in car, help?? [Re: NV69B7RR] #968654
04/11/11 01:54 PM
04/11/11 01:54 PM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
Any other ideas? Could it be the sheer pins?
