Re: What did I do wrong on my ministarter
[Re: StukaJU87]
#968581
04/08/11 11:35 PM
04/08/11 11:35 PM
Posts: 9,336 South-Central (Sebring), FL
Commando1
Ain't no stinkin (alignment) dowels.
There are two stinking dowels between the bellhousing and motor.
Yah, Iknow that and of course both dowelss are there. Reread the way he wrote the question. It inferred that there were dowels 'tween the starter and the B.H. I'll do the whistling around here. LMAO
[Re: Commando1]
#968584
04/09/11 12:08 AM
04/09/11 12:08 AM
Posts: 18,425 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Maybe if you quit whistling you could fix your problem......Word of advice. You cant expect what you dont inspect. Something is wrong and you have to be overlooking something. Thats a lot of starters to go through.
[Re: NITROUSN]
#968585
04/09/11 12:40 AM
04/09/11 12:40 AM
Posts: 30,457 Florida STAYcation
dOoC
The village idiot's idiot
Florida STAYcation
HE is either or .... what else would you expect from a SELFprofessed curmudgeon ?
[Re: dOoC]
#968590
04/09/11 01:56 AM
04/09/11 01:56 AM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
IF IT AIN'T BROKE - FIX IT TILL IT IS
Ya' BETTER pull this sig off your posts when talkin' to Ollie ....he follows THOSE "directions" really well !
JUST kiddin' Ollie ... ....or am I ?? ... ...
Doc, looks as if the old geezer fell asleep and is missing all this valuable info we're giving him.
[Re: B5 Bee]
#968591
04/09/11 02:01 AM
04/09/11 02:01 AM
dOoC
Florida STAYcation
The old geezer .... What a life he has ..... getting up at 11ish .... taking naps between CL searches ..... THEN he about having to go into-town to cash his fat pension check ... ... WE should all BEE so lucky ...
[Re: B5 Bee]
#968592
04/09/11 09:36 AM
04/09/11 09:36 AM
Commando1
Stan, the pics you posted of the Mancini starter, is that a pic from Mancinis file or the one you tried to install? If that's the starter you have, remove the BATT + cable lug and the black plastic housing it's attached to. There's another lug under it you can hook the BATT + cable to. The lugs plastic housing interferes with a freeze plug boss, take it off and your home free.
Cecil: That lower pic is mine. And yes, I removed the extension part. I just put in back on for the picture.
[Re: scratchnfotraction]
#968593
04/09/11 09:38 AM
04/09/11 09:38 AM
Commando1
have you tried to removing the dowl pins for the bell housing to aline the starter first?
I'm not falling for that one.
I don't need your sarcasm. It started off as a simple question on whether there was anything more I needed to know (I did my due diligence FIRST by Googling and searching). The thread took on a life of it's own. I've replaced more starters than you've changed underwear. I'm not worried about figuring out what happened here.
[Re: Commando1]
#968595
04/09/11 11:55 AM
04/09/11 11:55 AM
NITROUSN
By reading your post and the un-ability to correct your starter problem I would not argue with you on that statement.
FYI there was no sarcasm in my replies. I was trying to help. My comment on you cant expect what you dont inspect applies in a majority of unsolved issues.
Good luck. You have Doc F for support.
[Re: 69L78Nova]
#968596
04/09/11 01:21 PM
04/09/11 01:21 PM
Posts: 2,530 Nunya CA
CR8CRSHR
Nunya CA
I would have to disagree with you on this one. The stock "Boat Anchors" require more current draw and perform less effectively than the mini-starters. I won't even touch the fact that header interference with the stock starters is a PITA. Come on...step up to the 21st century and start running those mini's....
These cars were built with those "20th century" starters. Sure the OEM units are a little tougher to get in and out, but I have NEVER had a problem with fitment issues with headers out of all the cars I have had. I have a pile of the mini starters laying in my shed. I refuse to use them. I don't want my Charger or my Fury sounding like a Nissan when its turning over
As it is your prerogative to do so... Just for the record though...the newer mini starters that are from a 90's era MOPAR do not sound like a Nissan during turn over. More like a fine tuned and efficient MOPAR sound...At least it does to me...
[Re: Commando1]
#968599
04/09/11 03:54 PM
04/09/11 03:54 PM
Posts: 75,066 U.S.S.A.
JohnRR
U.S.S.A.
Doc got me cranked up this morning.
Wouldn't it be nice if when you put some d'bag on your ignore list that it wouldn't allow them to open or reply to anything the ignorer posted ?
