front end travel #968373
04/07/11 11:35 AM
04/07/11 11:35 AM
superstreet1896 Offline OP
Trying to figure out what way is the best to limit front end travel on 67 cuda. stock front end. torsion bars. qa1 single adjustable shocks. never had this issue with the ss springs in tha back and stock shocks up front but now that i have back halved the car, 4 link. the front end never really settles going down track. I would like it to be atleast level with the rest of the car. any ideas???
Re: front end travel [Re: superstreet1896] #968374
04/07/11 08:30 PM
04/07/11 08:30 PM
NC
440Jim Offline
440Jim  Offline
NC
Please clarify.
You seem to be asking two different questions.
1) Limiting front end suspension travel (extension)
2) Getting the front end to compress (settle down) going down the track at full power.
Re: front end travel [Re: 440Jim] #968375
04/08/11 12:37 AM
04/08/11 12:37 AM
well the more that i think of it, its both. the front shocks are not letting the front end down, while going down track. this could also be from the rear suspension being to soft. i had the rear shocks at full soft. but what i am trying to do is have the front end lower while under power going down track
Re: front end travel [Re: superstreet1896] #968376
04/08/11 01:04 AM
04/08/11 01:04 AM
MR_P_BODY Offline
MR_P_BODY  Offline
If the front moves freely(both up and down) you can
put a front spoiler on for down force on the front
but thats after you are SURE the front moves freely...
it could just be air getting under the front
Re: front end travel [Re: MR_P_BODY] #968377
04/08/11 11:14 AM
04/08/11 11:14 AM
PA
moparacer Offline
moparacer  Offline
PA
I have a 68 Dart with stock suspension and a 4 link and it does the same thing.
Maybe the IC settings on the 4 link?
My car likes a IC thats kinda long and high and it has loose shocks on it with the "drag" torsion bars.
I thought about trying a set of 340 bars or something with less stored energy than the drag bars have and maybe double adjustables up front to stiffen the extension to slow it down.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: front end travel [Re: moparacer] #968378
04/08/11 02:35 PM
04/08/11 02:35 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
I use cables on the Arrow...
5.53 @ 125 1/8th on the launch control..more left in her!
Re: front end travel [Re: Eric] #968379
04/08/11 07:19 PM
04/08/11 07:19 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i use a chain but cover it with a piece of wiring flexible conduit. it maybe rough but it works.
Re: front end travel [Re: rebel] #968380
04/08/11 07:37 PM
04/08/11 07:37 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
It's real easy to use the existing factory bracket for the upper control arm bump stop (visible in the above pic) and a tall rubber bumper with a threaded male end that goes through the bracket. You can adjust the height either by trimming the tip of the bumper, or placing a spacer or washers under it; my car uses a 1" tube with welded ends, which bolts to that bracket and the bumper attaches at the top.
