Flow number ? #968342
04/07/11 10:08 AM
04/07/11 10:08 AM
ohio
Rich970 Offline OP
Rich970  Offline OP
ohio
I was wondering is there a difference in flow numbers betwen a sf600 and a sf1020 flow bench with the same heads. Rich
Re: Flow number ? [Re: Rich970] #968343
04/07/11 10:47 AM
04/07/11 10:47 AM
MR_P_BODY Offline
MR_P_BODY  Offline
All benches tend to vary some... if you have the
2 benches side by side under the same conditions
with the same calibration they shouldnt but do...
unless your at the top end of the bench where they
tend to fall off... just like using a gauge... they
should be used in the mid portion of the unit... at
work we had 2 units next to each other and they were
very close ...JMO
Re: Flow number ? [Re: MR_P_BODY] #968344
04/09/11 10:00 AM
04/09/11 10:00 AM
ohio
Rich970 Offline OP
Rich970  Offline OP
ohio
Thanks MR P BODY. i just had my heads fully ported and added 2.25 valves and the flow #s came up about the same as the econo port job with 2.190 valves. flowed by different people and benches. ?
Re: Flow number ? [Re: Rich970] #968345
04/09/11 11:04 AM
04/09/11 11:04 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
numbers will never be the same
home of the
Sox and Martin Hemi Duster
Re: Flow number ? [Re: HEMIFRED] #968346
04/09/11 01:51 PM
04/09/11 01:51 PM
ohio
Rich970 Offline OP
Rich970  Offline OP
ohio
thats what i thought too. flow 353.9 econo port job ?
