Re: 1965 727 valve body question [Re: RTSrunner] #968199
04/09/11 03:23 PM
04/09/11 03:23 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
My valve body is cracked right next to the casting number,hairline with a small hole too!This would be an internal leak for sure.It may be repairable as it is on the top of the body away from the machined surface.
The early castings were prone to cracking in that area, don't bother trying to weld it, the heat is sure to warp it.
Re: 1965 727 valve body question [Re: John_Kunkel] #968200
04/09/11 05:23 PM
04/09/11 05:23 PM
Pittsburgh,PA
RTSrunner Offline OP
Pittsburgh,PA
Thanks John,no need for me to post a photo now!That is exactly how mine is cracked,but mine is a bit less visible.
RT
Re: 1965 727 valve body question [Re: John_Kunkel] #968201
04/10/11 10:34 AM
04/10/11 10:34 AM
moparx Offline
moparx  Offline
would that be repairable using hi-temp epoxy ?
Re: 1965 727 valve body question [Re: John_Kunkel] #968202
04/10/11 10:41 AM
04/10/11 10:41 AM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
Hay JK ...what caused that ? .. just a column/console shifter issue? I have never seen something like that. And I have done my fair-share of early TF's.
Re: 1965 727 valve body question [Re: RTSrunner] #968203
04/10/11 11:10 AM
04/10/11 11:10 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I'm getting ready to have a 65 trans built for my 57 wagon project, any build tips or converter choices before I get started? I am looking for a super dependable combo, mostly street driven but I'll flog it on occasion. Right now the trans and converter are all stock and untouched. Car combo is as follows:
413 Long Ram engine, bored to 426, short ram intakes, Hyd roller cam, 9:2:1 pump gas combo, 405HP/495TQ (dyno'd)
8.75 with 3.23 gears
14.00 wheels, not sure on tires yet
Weight 3,650 (light huh! )
Push button shifter
Re: 1965 727 valve body question [Re: moparx] #968204
04/10/11 05:27 PM
04/10/11 05:27 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Temperature isn't the problem, pressure is. I wouldn't trust any epoxy at the pressures that casting sees. (possibly over 300 psi)
The cracking problem only appears in the pre-'67 casting that has the square corner, I suppose it's a design flaw.
Re: 1965 727 valve body question [Re: ScottSmith_Harms] #968205
04/10/11 05:31 PM
04/10/11 05:31 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The input shaft on the early 727 limits converter choices, if it were mine I'd find a '67 or later (prfeferrably '71-'73) HP unit and swap the guts into the '65 case.
