1965 727 valve body question #968179
04/06/11 10:30 PM
04/06/11 10:30 PM
Pittsburgh,PA
RTSrunner Offline OP
Pittsburgh,PA
I have a '65 727 for my Coronet that needs a new valve body.It is a column shifted,cable operated trans.Are there other valve bodies that will interchange with this like a '64 or earlier push button,or is this a one year only VB? Freshening up the trans and a crack was found in a passage.Any clues appreciated!
Thanks,RT
Re: 1965 727 valve body question [Re: RTSrunner] #968180
04/06/11 10:59 PM
04/06/11 10:59 PM
Florida STAYcation
dOOc Offline
The village idiot's idiot
dOOc  Offline
Florida STAYcation
A PB VB will work IN the trans but NOT with the shifter. Where is the crack? post-a-pic?
If you want to stick with this combo(I know a bunch of guys that have put a PB dash in a 65) .... put a WANTED ad in here. I would think that there would be more "65" VB's than regular PB ones ... because the PB ones are more popular.
Re: 1965 727 valve body question [Re: dOOc] #968181
04/06/11 11:23 PM
04/06/11 11:23 PM
Pittsburgh,PA
Pittsburgh,PA
Doc,I found a '64 PB valve body for sale here in the ads.If the castings are the same,could the shifter parts be swapped from my column shift body to the PB body?I'm assuming if the casting numbers match it would be possible,unless they are machined differently. I don't have my valve body with me now,it is at a friends shop,sorry no photo!I don"t want to change to a PB setup.Should have put that clutch pedal in it and moved forward I guess!
Thanks.Ron
Re: 1965 727 valve body question [Re: RTSrunner] #968182
04/06/11 11:28 PM
04/06/11 11:28 PM
Florida STAYcation
dOOc Offline
dOOc  Offline
Florida STAYcation
Ron ....I do NOT think it is the same. But I am sure that John Kunkel would know. But in any case ... I think you would be better-off just waiting for the right one. Put a WANTED ad in now !
I used to have a BUNCH of these ... but they are long gone. All I have are PB VBs now.
Re: 1965 727 valve body question [Re: RTSrunner] #968183
04/07/11 08:19 AM
04/07/11 08:19 AM
York,Pa
Slap Shot Offline
Slap Shot  Offline
York,Pa
Re: 1965 727 valve body question [Re: Slap Shot] #968184
04/07/11 10:03 AM
04/07/11 10:03 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Contact John Cope at CRT.He can tell you everything about Mopar Trannys.Rocky
Chrysler Firepower
Re: 1965 727 valve body question [Re: dOOc] #968185
04/07/11 12:43 PM
04/07/11 12:43 PM
KY
rbds65 Offline
rbds65  Offline
KY
Yes, Mr. Kunkel will tell us the straight of it, but I believe if you keep your present detent and shift cable, you may be able to interchange PB and 65 valve bodies.
Re: 1965 727 valve body question [Re: RTSrunner] #968186
04/07/11 04:51 PM
04/07/11 04:51 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
A PB VB won't work with a console or column shifter; the PB VB's don't have a Park position for the manual valve in the main VB casting.
Simply changing the roostercomb and manual valve won't work either, there has to be a hole in the casting for the added position.
Re: 1965 727 valve body question [Re: John_Kunkel] #968187
04/07/11 10:14 PM
04/07/11 10:14 PM
Pittsburgh,PA
Pittsburgh,PA
Thanks for all the replies.I won't have my VB casting number until tomorrow.RO51 Hemi,thanks I did find the e-bay link to T-flite Patty,s dong a search.They show a correct VB in their list,have you bought anything from them?John Kunkel,thanks for clarification of the VB difference,PB to column/console.If I understand correctly the added detent keeps the column/console lever locked in the park position,where the PB was locked by the separate park lever.Is it possible for a PB valve body with the same casting number to have the necessary hole but unused?Or if no hole is present is it possible to modify it to work?
Thanks again,Ron
Re: 1965 727 valve body question [Re: RTSrunner] #968188
04/08/11 12:39 AM
04/08/11 12:39 AM
Florida STAYcation
dOOc Offline
dOOc  Offline
Florida STAYcation
Yeah Patty has got a large selection of unique stuff ..some of it - he is really PROUD of ...
For something like what you need .... again .. just put a wanted ad in here.
Re: 1965 727 valve body question [Re: dOOc] #968189
04/08/11 12:43 AM
04/08/11 12:43 AM
LA CA
bron_engines Offline
LA CA
A 65 cable trans is a cable trans period. The 65 column shift uses cables just like the PB does. Any 62 to 65 cable valve body will work with the 65 column cable shifter.
Re: 1965 727 valve body question [Re: RTSrunner] #968190
04/08/11 02:38 PM
04/08/11 02:38 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Is it possible for a PB valve body with the same casting number to have the necessary hole but unused? Or if no hole is present is it possible to modify it to work?
In '64 the casting number would be the same, the machining is what made them different. Boring the needed hole would be a precision machining operation, not a good idea to try at home.
Re: 1965 727 valve body question [Re: John_Kunkel] #968191
04/09/11 01:43 AM
04/09/11 01:43 AM
Pittsburgh,PA
Pittsburgh,PA
I found a valve body with the same casting number as mine.It was listed(for sale) as a PB body,but it was a core trans and the shifter PB or console was really unknown. I am going to get it and compare the two.My valve body is cracked right next to the casting number,hairline with a small hole too!This would be an internal leak for sure.It may be repairable as it is on the top of the body away from the machined surface.I will post a photo of the crack and follow up with the final resolution,be it replacement or repair.
RT
Re: 1965 727 valve body question [Re: RTSrunner] #968192
04/09/11 01:56 AM
04/09/11 01:56 AM
Florida STAYcation
dOOc Offline
dOOc  Offline
Florida STAYcation
That core trans ...where did you find that ? what year is it? ...do you want to sell what-is-left ?
Re: 1965 727 valve body question [Re: dOOc] #968193
04/09/11 02:14 AM
04/09/11 02:14 AM
Pittsburgh,PA
Pittsburgh,PA
Doc,No core trans for me,just the valve body.The seller of the VB had the core trans and installed a manual VB in it,so the stock VB is a leftover.
RT
Re: 1965 727 valve body question [Re: RTSrunner] #968194
04/09/11 02:18 AM
04/09/11 02:18 AM
Florida STAYcation
dOOc Offline
dOOc  Offline
Florida STAYcation
Cool RT ...was it a local score or off here ?
Re: 1965 727 valve body question [Re: dOOc] #968195
04/09/11 07:07 AM
04/09/11 07:07 AM
sw michigan
TB3CUDA Offline
TB3CUDA  Offline
sw michigan
not to hi-jack the post,but i just picked up a cable operated trans,is this a one year only trans?,it has 2 cables,and instead of a slip yoke,it has a round plate with 4 bolts that the driveshaft would attach to.is this a motor home trans or something older than i am use to seeing?
Re: 1965 727 valve body question [Re: TB3CUDA] #968196
04/09/11 07:47 AM
04/09/11 07:47 AM
Florida STAYcation
dOOc Offline
dOOc  Offline
Florida STAYcation
It could be many diff years ....it even could be a CAST IRON torqueflite. Do you have a pic?
Re: 1965 727 valve body question [Re: dOOc] #968197
04/09/11 08:10 AM
04/09/11 08:10 AM
sw michigan
TB3CUDA Offline
TB3CUDA  Offline
sw michigan
i sent you some,my pictures are too big to post here.
Re: 1965 727 valve body question [Re: TB3CUDA] #968198
04/09/11 08:18 AM
04/09/11 08:18 AM
AZ
Mike P Offline
Mike P  Offline
AZ
If it's aluminum, 2 cable with a flange it should be 62-64. I have a BB one set aside from when I was doing 57-58 Mopars.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold
1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold
1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears)
