Re: 1965 727 valve body question
[Re: Slap Shot]
#968184
04/07/11 10:03 AM
04/07/11 10:03 AM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
Contact John Cope at CRT.He can tell you everything about Mopar Trannys.Rocky
Chrysler Firepower
[Re: RTSrunner]
#968186
04/07/11 04:51 PM
04/07/11 04:51 PM
Posts: 25,794 Rio Linda, CA
John_Kunkel
Rio Linda, CA
A PB VB won't work with a console or column shifter; the PB VB's don't have a Park position for the manual valve in the main VB casting.
Simply changing the roostercomb and manual valve won't work either, there has to be a hole in the casting for the added position.
[Re: John_Kunkel]
#968187
04/07/11 10:14 PM
04/07/11 10:14 PM
Posts: 1,881 Pittsburgh,PA
RTSrunner
Pittsburgh,PA
Thanks for all the replies.I won't have my VB casting number until tomorrow.RO51 Hemi,thanks I did find the e-bay link to T-flite Patty,s dong a search.They show a correct VB in their list,have you bought anything from them?John Kunkel,thanks for clarification of the VB difference,PB to column/console.If I understand correctly the added detent keeps the column/console lever locked in the park position,where the PB was locked by the separate park lever.Is it possible for a PB valve body with the same casting number to have the necessary hole but unused?Or if no hole is present is it possible to modify it to work? Thanks again,Ron
[Re: TB3CUDA]
#968196
04/09/11 07:47 AM
04/09/11 07:47 AM
Posts: 30,424 Florida STAYcation
dOrk !
The village idiot's idiot
Florida STAYcation
not to hi-jack the post,but i just picked up a cable operated trans,is this a one year only trans?,it has 2 cables,and instead of a slip yoke,it has a round plate with 4 bolts that the driveshaft would attach to.is this a motor home trans or something older than i am use to seeing?
It could be many diff years ....it even could be a CAST IRON torqueflite. Do you have a pic?
[Re: TB3CUDA]
#968198
04/09/11 08:18 AM
04/09/11 08:18 AM
Posts: 1,511 AZ
Mike P
AZ
If it's aluminum, 2 cable with a flange it should be 62-64. I have a BB one set aside from when I was doing 57-58 Mopars.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold 1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold 1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears)
