383 A/C P/S to Non A/C Manual Steering question #968110
04/06/11 10:15 PM
04/06/11 10:15 PM
USA
JoesMopar Offline OP
USA
I have a 383 I'm building that had A/C components. The car it's going into is a non A/C, manual steering car.
Are pulley's specific to each set-up? I know on the A/C the alternator wraps around the A/C, but without it is it possible to route it to the WP and down to the crank?
I'm just not sure what exactly I need to tie the alternator, WP and crank together.
Re: 383 A/C P/S to Non A/C Manual Steering question [Re: JoesMopar] #968111
04/07/11 01:28 AM
04/07/11 01:28 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Non A/c uses different pulleys , one single belt tie all 3 together and the alternator mount is different from the A/C setup , find it used or Bouchillon sells it all .
