Plug cross reference
#968088
04/06/11 09:03 PM
04/06/11 09:03 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I have been running Champion RC12YC plugs in my 360/380 hp crate motor.I want to change to Autolites, what is the correct one to use? Thanks!
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Plug cross reference
[Re: '72CudaRacer]
#968092
04/08/11 10:06 AM
04/08/11 10:06 AM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
Thanks for posting the chart. I run the Champion C59CX plug and a week or two ago someone said the AR3910 was the same plug. The chart above shows the AR3933 is the same. Glad I had not ordered any yet. PS Is the C59YC a projected tip plug?
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: MRMOPAR622]
#968093
04/08/11 11:41 AM
04/08/11 11:41 AM
Posts: 2,930 Odessa, Tx.
cudarex
Odessa, Tx.
The equivalent AR3933 to the C59CX is a std. tip. The AR3910 is a projected tip.
