fixing stripped hole for exhaust stud in a 452 head
#968009
04/06/11 08:26 PM
04/06/11 08:26 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
The last time I messed with the hot rod it had a stripped hole for an exhaust stud. Since these holes are wet what's the best way to fix it? Will a heli coil provide a watertight seal under radiator pressure or should I look at doing something else?
