Motorhome 440,,carb@intake,,what choice's
#967938
04/06/11 06:49 PM
04/06/11 06:49 PM
dartman366
Mt. Vernon, Ohio
I have the origional intake and thermo quad on my 76 Winnie and just not satisfied with the way it work's or performs,intake is a smogger unit and the TQ has surging issues, seem's like the motor starts out pulling good when you first hit the gas and then flattens out after about 30 ft of travel and seem's lazy after that and get a whopping 4.5 mpg,,this thing need's help and would like some suggestions on a carb and intake selection.
Re: Motorhome 440,,carb@intake,,what choice's
[Re: dartman366]
#967940
04/06/11 08:20 PM
04/06/11 08:20 PM
Posts: 15,487 Florida
scratchnfotraction
I have a 78 mh 440 that had a stock smogger intake and thermobog swaped it for a weiand action plus with a 650cfm carter performance carb of course shaveing 60 foot of MH,adding the intake carb,striping down a short bed truck adding 3.91sg,manual VB,mono spring with lift bars it got plenty of torque with a stock 440,i am sure i will get a little better mpgs than that or try a Q-jet,holley spredbore 650 double pumper thermobog replacement those both worked good on mine when first getting it running
[Re: dartman366]
#967942
04/06/11 08:29 PM
04/06/11 08:29 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
You have a fuel delivery problem. It's delivering the wrong kind of fuel.
[Re: feets]
#967944
04/06/11 09:26 PM
04/06/11 09:26 PM
dartman366
Mt. Vernon, Ohio
Yeah ain't that the truth,, but it is what it is and I have to deal with it, this Thermo was sent out and rebuilt by what was supposed to be people that knew them, this thing cold start's and idles perfect, and rev's with no stumble's or issues but has what I would call a surge under load, the previous two owner's both said they rebuilt the carb and still had the same issue as me, so I think the carb has issues,,,Doc I will get you a carb number in the morning, but as far as I know it is origional to the motorhome, and also it has a set of headers and dual's so no heat riser.
[Re: dartman366]
#967945
04/06/11 09:30 PM
04/06/11 09:30 PM
dartman366
Mt. Vernon, Ohio
hey on the bright side,,,I did get the gas guage fixed today,,,and you won't in your wildest dream's guess what was wrong.
[Re: dartman366]
#967946
04/06/11 10:02 PM
04/06/11 10:02 PM
Posts: 396 California, USA
Phil Saran
California, USA
You were missing the ground strap on the fuel line at the gas tank?
If you are going to make changes and you don't have to worry too much about smog stuff go with a Edelbrock Performer intake and carb.
Phil Saran
Parker, Colorado
[Re: Phil Saran]
#967947
04/06/11 10:23 PM
04/06/11 10:23 PM
dartman366
Mt. Vernon, Ohio
actually,,,,,just the opposite, there was a wierd looking bracket laying on top of the tank across the sending unit post and grounding it out, I was in process of taking the tank out to put in a new sending unit and was investigating what I needed to do to get it out and noticed this bracket just lsying there on top of the tank so I took it off and tried the guage for the heck of it,,,,,and it worked.
[Re: dartman366]
#967948
04/06/11 10:36 PM
04/06/11 10:36 PM
Posts: 30,470 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
d-man ... it sounds like there is an issue on the primary side of the carb ...with surging. PROBABLY the wrong size rods in it.
I would suggest getting a spark plug reading at diff stages of running ...or BETTER YET .. put a wide-band 02 on it.
[Re: dOc !]
#967949
04/06/11 10:41 PM
04/06/11 10:41 PM
dartman366
Mt. Vernon, Ohio
don't know anybody that has a wide band,,,is there any good reference book's that would tell me what I should have in it,,,,,,,guess I should of bought that $20.00 swap meet thermo after all.
[Re: dartman366]
#967950
04/06/11 11:15 PM
04/06/11 11:15 PM
dOc !
Florida STAYcation
I don't have a wide-band yet either ... but I am going to get one.
The surging and poor mpg really don't go together(surging is lean - poor mpg is rich) ...uNless the carb tuning is totally messed up. At what speed is the surging taking place ?
Get a normal speed and high-speed read on the plugs for now. And you can ALWAY do better on the intake manifold.
[Re: dOc !]
#967953
04/06/11 11:42 PM
04/06/11 11:42 PM
dartman366
Mt. Vernon, Ohio
all new filters and new fuel pump, checked for kink's and smashed lines too.
[Re: dOc !]
#967955
04/06/11 11:59 PM
04/06/11 11:59 PM
dartman366
Mt. Vernon, Ohio
HOW did the filters look? ... metal ones ? ....did you pull em apart?
one at the carb was steel, small amount of verry verry fine silt came out, each tank has a clear chrysler type inline and they looked good like they had just been changed. but I changed them anyway.
[Re: dOc !]
#967957
04/07/11 12:26 AM
04/07/11 12:26 AM
dartman366
Mt. Vernon, Ohio
