Motorhome 440,,carb@intake,,what choice's
#967938
04/06/11 06:49 PM
04/06/11 06:49 PM
dartman366
Mt. Vernon, Ohio
I have the origional intake and thermo quad on my 76 Winnie and just not satisfied with the way it work's or performs,intake is a smogger unit and the TQ has surging issues, seem's like the motor starts out pulling good when you first hit the gas and then flattens out after about 30 ft of travel and seem's lazy after that and get a whopping 4.5 mpg,,this thing need's help and would like some suggestions on a carb and intake selection.
Re: Motorhome 440,,carb@intake,,what choice's
[Re: dartman366]
#967940
04/06/11 08:20 PM
04/06/11 08:20 PM
Posts: 15,487 Florida
scratchnfotraction
I have a 78 mh 440 that had a stock smogger intake and thermobog swaped it for a weiand action plus with a 650cfm carter performance carb of course shaveing 60 foot of MH,adding the intake carb,striping down a short bed truck adding 3.91sg,manual VB,mono spring with lift bars it got plenty of torque with a stock 440,i am sure i will get a little better mpgs than that or try a Q-jet,holley spredbore 650 double pumper thermobog replacement those both worked good on mine when first getting it running
[Re: dartman366]
#967942
04/06/11 08:29 PM
04/06/11 08:29 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
You have a fuel delivery problem. It's delivering the wrong kind of fuel.
[Re: feets]
#967944
04/06/11 09:26 PM
04/06/11 09:26 PM
dartman366
Mt. Vernon, Ohio
Yeah ain't that the truth,, but it is what it is and I have to deal with it, this Thermo was sent out and rebuilt by what was supposed to be people that knew them, this thing cold start's and idles perfect, and rev's with no stumble's or issues but has what I would call a surge under load, the previous two owner's both said they rebuilt the carb and still had the same issue as me, so I think the carb has issues,,,Doc I will get you a carb number in the morning, but as far as I know it is origional to the motorhome, and also it has a set of headers and dual's so no heat riser.
[Re: dartman366]
#967945
04/06/11 09:30 PM
04/06/11 09:30 PM
dartman366
Mt. Vernon, Ohio
hey on the bright side,,,I did get the gas guage fixed today,,,and you won't in your wildest dream's guess what was wrong.
[Re: dartman366]
#967946
04/06/11 10:02 PM
04/06/11 10:02 PM
Posts: 396 California, USA
Phil Saran
California, USA
You were missing the ground strap on the fuel line at the gas tank?
If you are going to make changes and you don't have to worry too much about smog stuff go with a Edelbrock Performer intake and carb.
Phil Saran
Parker, Colorado
[Re: Phil Saran]
#967947
04/06/11 10:23 PM
04/06/11 10:23 PM
dartman366
Mt. Vernon, Ohio
actually,,,,,just the opposite, there was a wierd looking bracket laying on top of the tank across the sending unit post and grounding it out, I was in process of taking the tank out to put in a new sending unit and was investigating what I needed to do to get it out and noticed this bracket just lsying there on top of the tank so I took it off and tried the guage for the heck of it,,,,,and it worked.
[Re: dartman366]
#967948
04/06/11 10:36 PM
04/06/11 10:36 PM
Posts: 30,431 Florida STAYcation
BeEtLeJuIcE !
The village idiot's idiot
Florida STAYcation
d-man ... it sounds like there is an issue on the primary side of the carb ...with surging. PROBABLY the wrong size rods in it.
I would suggest getting a spark plug reading at diff stages of running ...or BETTER YET .. put a wide-band 02 on it.
[Re: BeEtLeJuIcE !]
#967949
04/06/11 10:41 PM
04/06/11 10:41 PM
dartman366
Mt. Vernon, Ohio
don't know anybody that has a wide band,,,is there any good reference book's that would tell me what I should have in it,,,,,,,guess I should of bought that $20.00 swap meet thermo after all.
[Re: dartman366]
#967950
04/06/11 11:15 PM
04/06/11 11:15 PM
BeEtLeJuIcE !
Florida STAYcation
I don't have a wide-band yet either ... but I am going to get one.
The surging and poor mpg really don't go together(surging is lean - poor mpg is rich) ...uNless the carb tuning is totally messed up. At what speed is the surging taking place ?
Get a normal speed and high-speed read on the plugs for now. And you can ALWAY do better on the intake manifold.
[Re: BeEtLeJuIcE !]
#967953
04/06/11 11:42 PM
04/06/11 11:42 PM
dartman366
Mt. Vernon, Ohio
all new filters and new fuel pump, checked for kink's and smashed lines too.
[Re: BeEtLeJuIcE !]
#967955
04/06/11 11:59 PM
04/06/11 11:59 PM
dartman366
Mt. Vernon, Ohio
HOW did the filters look? ... metal ones ? ....did you pull em apart?
one at the carb was steel, small amount of verry verry fine silt came out, each tank has a clear chrysler type inline and they looked good like they had just been changed. but I changed them anyway.
[Re: BeEtLeJuIcE !]
#967957
04/07/11 12:26 AM
04/07/11 12:26 AM
dartman366
Mt. Vernon, Ohio
[Re: BeEtLeJuIcE !]
#967959
04/07/11 11:29 AM
04/07/11 11:29 AM
dartman366
Mt. Vernon, Ohio
luckily I don't take it far from home.
[Re: Twostick]
#967962
04/07/11 01:03 PM
04/07/11 01:03 PM
dartman366
Mt. Vernon, Ohio
I'd eliminate the obvious like fuel delivery and vacuum leaks. Assume nothing. New fuel pumps can under-perform and that thick base gasket for the TQ will leak if it's re-used too often. What is the timing at? Vacuum advance? The stock intake is WAY better than most will give credit for so it would be the last thing I would change. Can you borrow a TQ that is known good?
Kevin
new base gasket when the carb was put back on, I am not sure of the timing, I will have to investigate as to how difficult it will be to find the timing marks, then figure out where it should be set at, I would even concider a non smogger stock intake, as far as a different carb I will need to talk to a few friend's and see if they have somthing.
As far as YOU Ted, I have a spare Dommy for the car and I have seen M1's at swap meets so don't get me thinkin'........how about a tunnel ram and twin 750's.
[Re: Twostick]
#967964
04/09/11 08:56 PM
04/09/11 08:56 PM
dartman366
Mt. Vernon, Ohio
Checked the dist today and the advance is operable, I put some suction on it and it moves, but for the life of me I do not have a clue where the timing tab is, I have looked high and low and the only thing I have found is what look's like a metal tab sticking out under the water pump and there is no way to put a light on it if in fact that is the timing tab,,,I did find what I believe is the carb number stamped on the left rear (driver side) of the lower flange,, those number's are 9036S 290 5 does those number's mean anything to anyone? In response to a previous post, there was not an air pump on this motor when I got it but that don't mean there wasn't one before, there is some sort of fitting/hole,gnarly looking thing in the bottom of the manifold, isn't that the port for the EGR valve??
[Re: BeEtLeJuIcE !]
#967966
04/09/11 10:35 PM
04/09/11 10:35 PM
dartman366
Mt. Vernon, Ohio
d-man ... check out the timing THROUGH the hole in the top of the bell housing of the trans. BUT ... I would just time-it by ear. Give it timing til it starts to rattle... then back-it-off.
The 9036 is a good carb. You want to borrow(to test and maybe buy-it if you like-it?) an SP2P intake ? ... I will send you one .. you just pay the shipping charges.
Guess I need to do a little learnin', so in the morning I will go searching for a hole in the trans bell housing, I thought about timing by ear also, I did do a search and came up with the carb being a 75-76 truck w/california calibration,,sound's like I need to find a non california carb w/ standard calibration,,,,I will think your offer over, thank's
[Re: dartman366]
#967967
04/09/11 11:32 PM
04/09/11 11:32 PM
Posts: 6,562 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
You're right about the EGR. Don't know what I was thinking. I've never set the timing on a motorhome but I know that there is a 1+" hole in the top of the bell housing to shine your light thru.
Re: the advance. Do the weights move too? I think the vacuum can move the plate even if the weights are seized but I've already been wrong today. Something else to check.
Kevin
[Re: BeEtLeJuIcE !]
#967969
04/10/11 01:07 AM
04/10/11 01:07 AM
dartman366
Mt. Vernon, Ohio
d-man ... good point checking the distrib weight action. Also ...what does the tail-pipe look like? .. black soot? A little brain-fade on my part(for not mentioning it before) - the floats in the carb could have sunk.
Yeah the pipes are black and sooty, I have never had a TQ apart before but look's like I need to find out how to work on them.
[Re: dartman366]
#967970
04/10/11 02:46 AM
04/10/11 02:46 AM
BeEtLeJuIcE !
Florida STAYcation
ALL you have to do is go to a BIG 'brary and they either have or can get-you a FSM that should have the TQ data in it ...
[Re: BeEtLeJuIcE !]
#967973
04/10/11 03:24 AM
04/10/11 03:24 AM
Posts: 7,052 Madera, CA.
MowP4rsn
Madera, CA.
Yo Mo ......I have never seen that Federal-Mo edition of TQ data. I will have to print that out ...when I get to the 'brary.
But STILL ...from what I saw .. the FSM is BESTer.
But THX ferr 'da link ..Mo!
Yerrrr welcome, and there is a FSM on the Imperial Club site, too, look under the 1973 MY link
[Re: MowP4rsn]
#967974
04/10/11 07:11 PM
04/10/11 07:11 PM
dartman366
Mt. Vernon, Ohio
Found the timing hole today, it was hidden under the panel they attached the ignition box and the voltage reg to and bolted it using the top two bellhousing bolt's so it made it fun to find,, throwed a lite on it and could not find a mark on the converter to line up to the mark on the hole, so I just bumped the timing up what appeared a couple of degree's and the idle smoothed out even more, I thought it idled nice before, throttle seem's a little more responsive, also if you start it up after it has warmed up then shut it off and let it sit for a few hours, you can hit the starter and within a 1/2 revolution it is running,,guess now I need to hook up and take her for a tow.
