Spray paint removal on plastic or repaint?
#967585
04/06/11 10:13 AM
04/06/11 10:13 AM
Posts: 82 Michigan,United States
barracudadon383
The rear side panels in my '68 Barracuda convertible were spray painted white by someone else years ago. They are supposed to be black. I was wondering if there is a safe way to remove the paint or can I respray them black and make them look right? I'm trying to do a nice restoration so I don't want them to look crappy. Any suggestions? By the way...since I'm kind of new to restoration, I'm gonna have a ton more questions real soon....
Learnin' the hard way...
Re: Spray paint removal on plastic or repaint?
[Re: barracudadon383]
#967587
04/06/11 06:14 PM
04/06/11 06:14 PM
Posts: 4,723 Moved to N.E. Tennessee
GomangoCuda
I seem to recall someone suggesting brakefluid for this but I would try it on the back side first just in case.
[Re: boydsdodge]
#967591
04/06/11 07:41 PM
04/06/11 07:41 PM
Posts: 10,570 Sunny South Florida
Golden-Arm
Sunny South Florida
get a cheapie paintbrush, and brush a layer of brake fluid over the panel. lay it flat, and let it sit for a while. you can use a scrub brush or a pressure washer, on low power, and the paint will come off, in a sheet. stubborn spots, just reapply. you'll notice the paint start to wrinkle, before it starts lifting off the plastic. brake fluid wont eat up plastic. we use if for stripping factory paint off model cars, planes and trains by soaking them in a jar or tray with fluid. use it sparingly, as in reality, you're washing it into the ground or drain, depending on where you do the stripping at. some grease cutting dish detergent when you're done, will remove any traces of the fluid, in preparation for painting.
#967593
04/07/11 01:39 AM
04/07/11 01:39 AM
Posts: 1,100 Fort Lauderdale
Dave440
Fort Lauderdale
Im not crazy with the brake fluid idea bcus then you have to make sure its all gone or new paint will never stick. Not to mention its messy and the environmental impact when you clean it off. Laquer thinner not great either. Might or might not remove old paint but might melt away any grain texture on the plastic.
You MIGHT try outside with a nice cross breeze.... Easy off foaming oven cleaner. It contains lye (or used to...not sure now) and is caustic so wear gloves and goggles...dont get the spray in your eyes or breath it in. (then again...it is meant for ovens indoors....but I dont recommend breathing it and keep it off your skin).
Its an old trick model builders use to remove paint on plastic models without melting the model. Done it several times myself. Try using laquer thinner on a plastic model and see what happens.... melted blob! EZ off wont do that. Let the ez off sit a while then use a scrunge to scrub the surface. It might take a few applications scrubbing in between and a bit of time but it should work. Rinse thoroughly with water when done then wash thoroughly with another clean sponge using grease cutting dish soap like palmolive, joy etc... Use the kind without additives like aloe. JUST soap. Once dry it should be ready for paint. For best adhesion get plastic purposed spray paint....think krylon or rustoleum make it. The paint should be avail at walmart and likely home depot.
[Re: Dave440]
#967594
04/07/11 09:12 AM
04/07/11 09:12 AM
barracudadon383
If I can get all the white paint off I shouldn't need to paint them at all. They are already black under the white paint. At least that's what I was thinking....
#967600
04/10/11 01:31 AM
04/10/11 01:31 AM
Posts: 1,179 Canada
demon
Canada
I use graffiti remover all the time in my shop for just such problems. Works excellent on door weatherstrips and those ole Chevy-ised spraybomb black engine bays. The product I use is Lloyds Fight Back. Has a citrus smell. Removes spray bomb and repaints very nicely without harming anything underneath. Highly recommended
