Exhaust manifold heat shield sealing question. #96738
07/29/08 08:37 PM
07/29/08 08:37 PM
Seattle, WA
W
waguy Offline OP
waguy  Offline OP
W
Seattle, WA
I am about to install a 273 into my 65 Dart wagon and I'd like to use the old heat shield gaskets on the exhaust manifolds. They are in very good condition but I am worried that they will not seal properly. This is not a problem that I want to worry about in the tight, early A-body compartment! Should I use gaskets in addition to the shields? Sealer? Or should I omit them entirely? Thanks for any help!
Re: Exhaust manifold heat shield sealing question. [Re: waguy] #96739
07/29/08 08:42 PM
07/29/08 08:42 PM
Just Reuse them, it it leaks then ya gotta redo it , i know its abummmer.but when ya try to add other stuff thats when they usually leak.
Re: Exhaust manifold heat shield sealing question. [Re: waguy] #96740
07/29/08 10:41 PM
07/29/08 10:41 PM
Ridgeland Wi
mopars_1 Offline
mopars_1  Offline
Ridgeland Wi
I know some people say you don't even need an exhaust manifold gasket. Id just go ahead and reuse it.
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
