UPDATE: Gas/Fumes smell inside car and garage
#967240
04/05/11 09:01 PM
04/05/11 09:01 PM
Posts: 3,344 Central TX
roe
Central TX
Heres the background. Car used to be 318/904 2bbl and I never had any issues. Then I switched to a 360/904 4bbl and thats when it started. When driving there is a fuel/fume smell inside the car and its very noticable, and starts to bother me when Im in the car for long rides, especially around town when I cant get a high volume of air flowing into the car. There are two lines that come up towards the motor on the passenger side of the engine bay. One is the fuel line that runs from the fuel sender/fuel pump. The other, which also follows the fuel line from the tank, is what some people called a vapor line for emissions. They said it was definately not a fuel return line. Does it allow the fuel tank to vent properly, and not cause it to create a vacuum in the tank causing fuel starvation? Because when I go to refill my tank now there is a very noticable swoosh of air when I remove the gas cap, enough that it startled me the first time. Also, when I park the car, I can walk back into the garage and Im overpowered by the smell of gas/fumes. I even put on a brand new vented gas cap to rule that out since the one I had was so old, it had no effect. My new carb, eddie 1406 does not a fitting for this vapor line? I have it blocked off right now, is this my problem. Should I just leave it open? Should it be hooked to a breather tube, or air cleaner? roe
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
Re: Gas/Fumes smell inside car and garage
[Re: Challenger 1]
#967242
04/05/11 09:09 PM
04/05/11 09:09 PM
roe
Central TX
sorry. sig car, '71 satellite
[Re: Challenger 1]
#967244
04/05/11 10:03 PM
04/05/11 10:03 PM
roe
Central TX
No not in trunk. It appears to be mounted in the wheelwell on the driverside rear. The four hoses leave the driver side of the tank and tuck up into the wheelwell, and there is a panel there that I can unbolt after I remove the rear tire. All 4 of the hoses are there and intact. Old, but don't seem to be cracked/leaking, and still feel flexible when I wiggled them. It just seems to have started after the carb switch, now that that secomd line I mentioned is not used.
[Re: roe]
#967246
04/05/11 10:09 PM
04/05/11 10:09 PM
roe
Central TX
Now that I think about it, I belive that second line usedto be connected to a small nipple on the valvecover breather when I had the 2bbl carbon and air cleaner. But I can't remember for sure. When I swapped on the 4bbl I had to change the air cleaner, which also made me put on one of those breathers that's just a filter. I stillhave that breather I believe, but can'tremember for sure if that's how it was hooked up. Whadaya think?
[Re: Challenger 1]
#967251
04/05/11 11:41 PM
04/05/11 11:41 PM
roe
Central TX
Ok, PCV valve is on and functioning on the driver side. I just put a new one on with the last tuneup. I still have the original style breather so I will give that a shot first, and I'll probably relpace the vapor seperator and hoses to it while Im at it. I'll report back with results
Thanks guys. roe
[Re: roe]
#967253
04/05/11 11:54 PM
04/05/11 11:54 PM
roe
Central TX
Where can I find a fuel vapor seperator? I saw nothing on rockauto or autozones website. I'll try giving them a call tomorrow to see what rockauto says.
[Re: 2cudabuck]
#967255
04/06/11 12:10 AM
04/06/11 12:10 AM
roe
Central TX
Yeah, I looked at that thread as well, didn't want to throw off what the OP was looking for so I started this one. I will definately examine mine for any rust holes or anything like that, replace my rubber hoses going to the vapor seperator, and reconnect my vent line to the breather and go from there.
[Re: roe]
#967256
04/06/11 10:59 PM
04/06/11 10:59 PM
roe
Central TX
Here is the pic of the spare valvecover breathers. I tried the one that has only one nipple on it, and connected the vent line to it. It actually made the car run worse. Stumbling at idle like it wanted to die on me. Took it back loose and left the vent tube hanging open and it ran smooth again.
[Re: roe]
#967257
04/06/11 11:02 PM
04/06/11 11:02 PM
roe
Central TX
Here is the pic of the vent tube, the one that has the white tape strip on it in the bottom left. The tube ends pretty much where u see the tape. Also, you can see the style of valvecover breather Im running.
