Holley 600 running wide open after install???
#967043
04/05/11 03:45 PM
04/05/11 03:45 PM
Posts: 3,445 N.Wilkesboro,NC
DusterKrazy
N.Wilkesboro,NC
I have a Holley 600cfm vacumn secondary carb with electric choke. It seems any possible vacumn leaks have been plugged off and the throttle linkage seems to be setup ok as well. It's on a 400 with a squarebore intake ('68 or '69) with no adapter plate-just a gasket. The electric choke is not hooked up but would that cause it be revving that high?? I don't think so?? The carb was running fine on my '69 Barracuda
Re: Holley 600 running wide open after install???
[Re: johnedod]
#967045
04/05/11 03:59 PM
04/05/11 03:59 PM
Posts: 5,443 Indiana
YO7_A66
Indiana
Can you move the carb linkage with your hand? Do you have the throttle return spring hooked up?
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: Leigh]
#967047
04/05/11 08:22 PM
04/05/11 08:22 PM
DusterKrazy
N.Wilkesboro,NC
Thanks folks.. I found the issue. The primaries were open because of how the throttle cable was attached. It's installed and running great but I have not quite figured out the best way to hook up my throttle cable and kickdown linkage. It's a modified Holley from some carb shop out in Texas. So far, it runs leaps and bounds above the Edelbrock 750 that was on there. I have not taken it out on the road. If anybody can show me their installed Holley carb, it is much appreciated!
[Re: DusterKrazy]
#967048
04/05/11 09:05 PM
04/05/11 09:05 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
get the HOLLEY/MOPAR linkage adapter or it will never be right.....
I am truckless..
[Re: 340SHORTY]
#967049
04/05/11 11:14 PM
04/05/11 11:14 PM
DusterKrazy
N.Wilkesboro,NC
Thanks..can anybody get me a pic of this? or Part#??
