Holley 600 running wide open after install??? #967043
04/05/11 03:45 PM
04/05/11 03:45 PM
N.Wilkesboro,NC
DusterKrazy Offline OP
N.Wilkesboro,NC
I have a Holley 600cfm vacumn secondary carb with electric choke. It seems any possible vacumn leaks have been plugged off and the throttle linkage seems to be setup ok as well.
It's on a 400 with a squarebore intake ('68 or '69) with no adapter plate-just a gasket. The electric choke is not hooked up but would that cause it be revving that high?? I don't think so??
The carb was running fine on my '69 Barracuda
Re: Holley 600 running wide open after install??? [Re: DusterKrazy] #967044
04/05/11 03:58 PM
04/05/11 03:58 PM
Clintwood VA
johnedod Offline
johnedod  Offline
Clintwood VA
Check and make sure the secondaries aren't stuck open a little.
Johnedod
68 Road Runner
71 Road Runner
78 Power Wagon
Re: Holley 600 running wide open after install??? [Re: johnedod] #967045
04/05/11 03:59 PM
04/05/11 03:59 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
Can you move the carb linkage with your hand?
Do you have the throttle return spring hooked up?
Re: Holley 600 running wide open after install??? [Re: DusterKrazy] #967046
04/05/11 04:44 PM
04/05/11 04:44 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Some manifolds will not let the secondary arm clear. I had to use a 1/4" heat insulator type gskt with a 3310 and LD340, for example.
Re: Holley 600 running wide open after install??? [Re: Leigh] #967047
04/05/11 08:22 PM
04/05/11 08:22 PM
N.Wilkesboro,NC
N.Wilkesboro,NC
Thanks folks..
I found the issue. The primaries were open because of how the throttle cable was attached. It's installed and running great but I have not quite figured out the best way to hook up my throttle cable and kickdown linkage.
It's a modified Holley from some carb shop out in Texas. So far, it runs leaps and bounds above the Edelbrock 750 that was on there. I have not taken it out on the road.
If anybody can show me their installed Holley carb, it is much appreciated!
Re: Holley 600 running wide open after install??? [Re: DusterKrazy] #967048
04/05/11 09:05 PM
04/05/11 09:05 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
get the HOLLEY/MOPAR linkage adapter or it will never be right.....
I am truckless..
Re: Holley 600 running wide open after install??? [Re: 340SHORTY] #967049
04/05/11 11:14 PM
04/05/11 11:14 PM
N.Wilkesboro,NC
N.Wilkesboro,NC
Thanks..can anybody get me a pic of this? or Part#??
Re: Holley 600 running wide open after install??? [Re: DusterKrazy] #967050
04/05/11 11:27 PM
04/05/11 11:27 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
