Number one position on big block distributor cap?? #966803
04/05/11 12:36 PM
04/05/11 12:36 PM
N.Wilkesboro,NC
DusterKrazy Offline OP
N.Wilkesboro,NC
It's my first big block and I need a diagram showing where the number one plug wire position is on the cap if possible. Thanks!
Re: Number one position on big block distributor cap?? [Re: DusterKrazy] #966804
04/05/11 01:03 PM
04/05/11 01:03 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Line up the timing marks and look to see where the rotor is pointing. It will either be #1 or 180* out which is easy to change.The reason to do it this way is that the distributor drive may have been removed and installed in a different position than factory. That would put the #1 in a different place on the cap.
Re: Number one position on big block distributor cap?? [Re: DusterKrazy] #966805
04/05/11 01:12 PM
04/05/11 01:12 PM
Montana
Y
Yancy Derringer Offline
Y
Montana
The thing is, the "right place" is only "right" if the intermediate shaft (oil pump /distributor drive) is installed correctly.
So what you need to do if find out where it needs to be to time the engine.
Pull out the no1 spark plug, rig a remote starter switch or get a friend to operate the key, and stick your finger in the plug hole. Bump the engine until it blows your finger out on compression. It probably will help to do this a couple of times so you are sure what to look for and STOP when the compression first starts
Then look to the timing marks which should be "coming around." Bump the engine until the timing marks are where you want the initial timing set, say, 10* BEFORE top dead center, or BTC.
Assuming the engine has been running OK, pull the cap, and where the rotor is "coming to" is your no1 plug tower. Bear in mind that the BB/ RB distributors rotate COUNTER clockwise.
In order to set the timing "good enough to start" in this condition, the points should be just opening, or the reluctor should be close to the center of the pickup coil.
If this is a "new start" and the timing is not "set," rotate the dist. retarded (ccw) and then bring it advanced (cw for a big block) until the points just open.
In the case of breakerless, you can turn on the key, rig a spark gap such as a plug hooked to the coil wire, and rotate the dist. from retard to advance (cw) until it sparks. By doing this several times back and forth, you can get a "feel" for where the spark happens, and by slowing down your movements each time, you can accurately gauge where the spark is made. Stop the dist right at this point and the engine should start and run.
So far as the "book" that is, "the right tower" Once again, it depends on how the distributor driver shaft was installed.
The only reason on most engines that there is a specified "right way" is:
So the assembly line folks can "wrench repeat"
So the plug wires "lay" nice
So the tuneup mechanics "see" what they expect.
Otherwise, on a geared distributor like a GM, you can just bring the engine up to 10BTC or so, "throw" the distributor in, and plug the no1 wire into wherever the rotor happens to be pointing.
Here's the picture from the shop manual:
Re: Number one position on big block distributor cap?? [Re: Yancy Derringer] #966806
04/05/11 01:54 PM
04/05/11 01:54 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Find TDC by taking out number one plug and slowly turning the engine over till you feel compression coming out the hole the very slowly finish bringing so that the timing marks line up at TDC. Install the intermediate shaft so that the slot is parallel with the engine center line. Install the distributor so that the rotor is point to the front of the engine install the cap and put the number one wire where the rotor was pointing and follow the firing order around the cap in counter clock fashion.
If the distributor is in find TDC compression and look where the rotor is pointing and install number 1 in that terminal in the cal and follow the firing order around the cap CC on BB. It make ) difference where the rotor point at TDC as long as you install number one wire in that terminal and follow the firing order around from that point. he engine don't care where you locate number one in the cap as long as the rotor points to that terminal at TDC firing and firing order is followed around. (or slightly advance till final timing.
Re: Number one position on big block distributor cap?? [Re: DusterKrazy] #966807
04/05/11 07:23 PM
04/05/11 07:23 PM
If the cap order is all set/wires in place & you had the inter gear out for some reason or a diff dist w different phasing (some are diff), clock the inter gear so it puts the rotor under the current #1 wire. If starting from scratch either cut to fit wires or if you can mix/match wires to get the right lengths on the right plug then go w the OE #1 in the pic which is always a good idea for standardization
