Need to know where the 2 ports that come out of the top left front side of the gas tank go to, someone previously looped a small piece of hose from one to another forming a "U".
Added cold fuel, outside temperature was @ 80 degrees, sprewed fuel from the main vent line like a faucet was opened until the gas cap was opened, then it stopped, all within 10 minutes of adding fuel.
Only had 1/2 tank of fuel so I know it wasn't overly filed. This is why I was asking about the 2 small ports on the top left portion of the gas tank as to what their function is, are they vents as well?
I know I need a FSM but until I get one, I would like to see if anyone could shed some light on the 2 small ports on the tank as to their actual function and use.
