68 Roadrunner gas tank information #966767
04/05/11 12:02 PM
04/05/11 12:02 PM
MD, Northern VA
Z
zrwhat Offline OP
zrwhat  Offline OP
Z
MD, Northern VA
Need to know where the 2 ports that come out of the top left front side of the gas tank go to, someone previously looped a small piece of hose from one to another forming a "U".
Added cold fuel, outside temperature was @ 80 degrees, sprewed fuel from the main vent line like a faucet was opened until the gas cap was opened, then it stopped, all within 10 minutes of adding fuel.
Only had 1/2 tank of fuel so I know it wasn't overly filed. This is why I was asking about the 2 small ports on the top left portion of the gas tank as to what their function is, are they vents as well?
I know I need a FSM but until I get one, I would like to see if anyone could shed some light on the 2 small ports on the tank as to their actual function and use.
Re: 68 Roadrunner gas tank information [Re: zrwhat] #966768
04/05/11 02:45 PM
04/05/11 02:45 PM
Clintwood VA
johnedod Offline
johnedod  Offline
Clintwood VA
They are vents. One goes thru a grommet in the trunk and a metal line runs across then turns back down thru another grommet into the frame rail. On mine the other one goes to a small metal line shaped like a hook and attaches to the shock crossmember.
Johnedod
68 Road Runner
71 Road Runner
78 Power Wagon
