Page 1 of 3 1 2 3
The Good, The Bad and The Ugly #966030
04/04/11 08:19 PM
04/04/11 08:19 PM
On the south side of Nowhere
S/ST 3040 Offline OP
I finally tore the 340 down from last year's breakage at Norwalk.
The good...........heads, valves, cam, lifters are all OK.
The bad............the block is going to need a sleeve but, will live.
Here's the ugly..........
Re: The Good, The Bad and The Ugly [Re: S/ST 3040] #966031
04/04/11 08:20 PM
04/04/11 08:20 PM
Re: The Good, The Bad and The Ugly [Re: S/ST 3040] #966032
04/04/11 08:21 PM
04/04/11 08:21 PM
South Jersey, NJ
DragDart360 Offline
DragDart360  Offline
South Jersey, NJ
Ouch!
70 Dart Swinger, 2850 lbs
SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
Re: The Good, The Bad and The Ugly [Re: S/ST 3040] #966033
04/04/11 08:22 PM
04/04/11 08:22 PM
Re: The Good, The Bad and The Ugly [Re: S/ST 3040] #966034
04/04/11 08:23 PM
04/04/11 08:23 PM
The rest of the crank looks like this.
Re: The Good, The Bad and The Ugly [Re: S/ST 3040] #966035
04/04/11 08:24 PM
04/04/11 08:24 PM
Re: The Good, The Bad and The Ugly [Re: S/ST 3040] #966036
04/04/11 08:27 PM
04/04/11 08:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Vic I dont recall you breaking it... bummer
Re: The Good, The Bad and The Ugly [Re: S/ST 3040] #966037
04/04/11 08:29 PM
04/04/11 08:29 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
What rods are those?
That sucks, hope ya get her back up and running.
Kasey
Re: The Good, The Bad and The Ugly [Re: S/ST 3040] #966038
04/04/11 08:31 PM
04/04/11 08:31 PM
If you ever get enough water or fuel in a cylinder to hydraulic
it, pull it apart and check the bearings. If it was real bad, it
might bend the rod too.
Re: The Good, The Bad and The Ugly [Re: S/ST 3040] #966039
04/04/11 08:33 PM
04/04/11 08:33 PM
Moparnut426 Offline
Moparnut426  Offline
I was just curious cause they almost look like childs rods, and they Look like they held up well for what broke. Im sure it was buzzin pretty good too. My track master rods look similar to those.
Kasey
Re: The Good, The Bad and The Ugly [Re: Moparnut426] #966040
04/04/11 08:34 PM
04/04/11 08:34 PM
Scat I-beams. No fault of any component. I screwed
up a rod bearing with a leaking head.
Re: The Good, The Bad and The Ugly [Re: MR_P_BODY] #966041
04/04/11 08:36 PM
04/04/11 08:36 PM
I vividly recall it. Plenty of witnesses too.
Re: The Good, The Bad and The Ugly [Re: S/ST 3040] #966042
04/04/11 08:37 PM
04/04/11 08:37 PM
Moparnut426 Offline
Moparnut426  Offline
Oh, thats no good. I like scat rods, they are in 3 engines Ive built, and they are so far OK. My 408 has the Childs track master rods in it, just because I got a screaming deal.
Do ya have another crank, I may have one laying around.
Kasey
Re: The Good, The Bad and The Ugly [Re: Moparnut426] #966043
04/04/11 08:39 PM
04/04/11 08:39 PM
ohio
all spooled up Offline
ohio
thats pretty bad i was there he has some screaming rpm out of the water
Re: The Good, The Bad and The Ugly [Re: Moparnut426] #966044
04/04/11 08:39 PM
04/04/11 08:39 PM
I think I already have one but, thanks.
Re: The Good, The Bad and The Ugly [Re: S/ST 3040] #966045
04/04/11 08:40 PM
04/04/11 08:40 PM
Moparnut426 Offline
Moparnut426  Offline
No problem. What RPM you run that? I see its bushed, so must be solid roller? How bout some specs?
I love stock stroke screamers.
Kasey
Re: The Good, The Bad and The Ugly [Re: Moparnut426] #966046
04/04/11 08:47 PM
04/04/11 08:47 PM
8200 RPM
10.28:1 pump gas, OEM heads, Victor 340, Pro Systems 950, Hooker headers, 904, Dana 60.
Re: The Good, The Bad and The Ugly [Re: S/ST 3040] #966047
04/04/11 08:57 PM
04/04/11 08:57 PM
Moparnut426 Offline
Moparnut426  Offline
HOLY SHEEEEEEEET!
Thats awsome.
I had a set of W2 heads off of a 340 in a rail that belonged to a fella in Fremont Nebraska. He ran through the traps at 9K, and you could have swore the thing was going to lift off too the moon. Those heads ended up being WAY to big for my set up at the time, and Jesse from Sioux City has them now. He screwed me pretty hard on the J heads I traded for.
Kasey
Re: The Good, The Bad and The Ugly [Re: Moparnut426] #966048
04/04/11 09:07 PM
04/04/11 09:07 PM
I haven't seen Jesse here for a looooong time.
That sucks. These are 974 castings.
Re: The Good, The Bad and The Ugly [Re: S/ST 3040] #966049
04/04/11 09:14 PM
04/04/11 09:14 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
soooooooo,, when's the new bullit going to be dropped in the car??
Page 1 of 3 1 2 3
