Dodge RamMulti-Displacement System monitoring?? #96602
07/29/08 02:04 PM
07/29/08 02:04 PM
Gibsons BC Canada
dalei989 Offline OP
dalei989  Offline OP
Gibsons BC Canada
Does anyone make a device to tell when the Multi-Displacement System is on. I have a 07 hemi charger and a 08 ram 1500, but I don't really feel much of a difference driving so I don't when the mds system is being used. thanks
1971 340 Swinger Canadian Car
1972 Dodge Dart Prostreet 440
2013 Dodge Ram 1500
Re: Dodge RamMulti-Displacement System monitoring?? [Re: dalei989] #96603
07/29/08 03:29 PM
07/29/08 03:29 PM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
a cat back exhaust?
Basically with the exhaust slightly louder, you can hear it drop cylinders and the more cylinders it drops the worse it sounds.
Never heard of a little indicator light or anything along those lines...sorry
Re: Dodge RamMulti-Displacement System monitoring?? [Re: dalei989] #96604
07/29/08 07:44 PM
07/29/08 07:44 PM
hops440 Offline
hops440  Offline
Re: Dodge RamMulti-Displacement System monitoring?? [Re: hops440] #96605
07/29/08 10:48 PM
07/29/08 10:48 PM
Gibsons BC Canada
dalei989 Offline OP
dalei989  Offline OP
Gibsons BC Canada
Seems simply enough to do, thanks
2013 Dodge Ram 1500
Re: Dodge RamMulti-Displacement System monitoring?? [Re: hops440] #96606
07/30/08 08:07 AM
07/30/08 08:07 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
The scangauge aftermarket trip computer and OBD-II monitoring readout will also show when MDS is engaged, plus what engine conditions are necessary:
http://www.scangauge.com/
if you are fiddling with MDS
you might also read this Australian post
and consider a capacitor/resistor filter
on the TPS that might keep MDS on longer
and prevent it dropping out with little throttle jerks
http://www.autospeed.com/cms/A_110187/article.html?popularArticle
Re: Dodge RamMulti-Displacement System monitoring?? [Re: 360view] #96607
07/30/08 12:17 PM
07/30/08 12:17 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I record the MDS on our shop computer and I can hardly ever feel it drop out and I know it works because I will see it on the recording when I get back in the shop. Ron
