Best Carb Spacer for RPM Air Gap #966016
04/04/11 08:12 PM
04/04/11 08:12 PM
dusterjp Offline OP
dusterjp  Offline OP
I will be taking my car to the dyno soon to try a couple of different intakes. I have a Super Victor and an RPM Air Gap. I would like to try a 1" carb spacer on the Air Gap but not sure which type would work best with a dual plane intake, a tapered 4 hole or an open spacer. Does anyone have any dyno or track results? All advice is appreciated. Thanks.
Re: Best Carb Spacer for RPM Air Gap [Re: dusterjp] #966017
04/04/11 11:06 PM
04/04/11 11:06 PM
AndyF Offline
AndyF  Offline
Open usually works the best on a dual plane intake to make power. Throttle response sometimes isn't as good though.
Re: Best Carb Spacer for RPM Air Gap [Re: AndyF] #966018
04/04/11 11:15 PM
04/04/11 11:15 PM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
most results I have seen were nominal to none at all. But always worth trying if you have the dyno time.
Re: Best Carb Spacer for RPM Air Gap [Re: dusterjp] #966019
04/05/11 03:19 PM
04/05/11 03:19 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
HVH recommends a 4-hole for the Air Gap.
http://www.highvelocityheads.com/ss.htm
As previously stated, since you have dyno-time try an open and 4-hole to find out how your setup responds.
Please share your findings.....
Re: Best Carb Spacer for RPM Air Gap [Re: cruzin] #966020
04/05/11 08:03 PM
04/05/11 08:03 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Yes, old rule of thumb (don't know whose thumb!), 4 hole spacer on dual plane, open spacer on single plane. Let us know if that's what your dyno shows!
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Best Carb Spacer for RPM Air Gap [Re: GO_Fish] #966021
04/05/11 10:31 PM
04/05/11 10:31 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
This has worked best on mine...1" open fully blended, thinned, and lowered center divider
Re: Best Carb Spacer for RPM Air Gap [Re: Dragula] #966022
04/12/11 09:42 PM
04/12/11 09:42 PM
Dragula Offline
Dragula  Offline
Figures....I post mine, and all I get is the sound of crickets
Re: Best Carb Spacer for RPM Air Gap [Re: Dragula] #966023
04/12/11 10:53 PM
04/12/11 10:53 PM
70duster340 Offline
70duster340  Offline
Looks good, did you do the work yourself?
Re: Best Carb Spacer for RPM Air Gap [Re: 70duster340] #966024
04/13/11 07:55 AM
04/13/11 07:55 AM
Dragula Offline
Dragula  Offline
Yes....
