Re: Max lift on stock 906 heads?
[Re: JohnRR]
#965925
04/04/11 06:25 PM
04/04/11 06:25 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
I ran a voodoo with 533 and worked great changed it to a voodoo with like 550 and it wouldnt rev past 6200 rpm. Could have been the springs but I assumed I had some interference with the stock 906 heads.
67' charger 499 RB
10.57 at 127
[Re: AutoEngineer]
#965929
04/06/11 12:08 AM
04/06/11 12:08 AM
Posts: 1,153 Adrian, Mi
pro6pakRR
mopar addict
mopar addict
Adrian, Mi
What is the max cam lift on stock 906 heads with stock valves and stamped steel rockers?
I run a Mopar 533 hyd with bone stock 346 head's,rocker and pushrods,in my 12.50 engine.
[Re: JohnRR]
#965930
04/06/11 03:09 AM
04/06/11 03:09 AM
Posts: 4,255 State of Fascism
52savoy
State of Fascism
Just measure it, why speculate?
That would only make sense , but I think his more important question is how much lift can stamped steel rockers handle ?
I've ran a .560 lift with stock rockers and it was together for many years. But then the heads were 915's
[Re: scatpacktom]
#965931
04/06/11 01:40 PM
04/06/11 01:40 PM
Posts: 179 Up in the North and Far Away
AutoEngineer
Sorry, but I was not in my garage, when wrote that question and my garage is over 35 miles from my office, and I needed a honest answer because from Hughes Engines they said maximum lift with stock guide height is 0.450". More lift would require shortening the valve guides. I thought it's a little bit low, because I have even earlier used cams up to 0.507 without shortening guides.
[Re: pro6pakRR]
#965932
04/06/11 03:58 PM
04/06/11 03:58 PM
Posts: 5,186 Wherever I am.
Junky
Wherever I am.
Stock on top 346 heads, 0.518 lift with room to spare.
